Discussing turbo hotside for 96-04 gt in the Power Adders Forum. POSTING FOR A FRIEND This is Hot side only.... Fits 2v GT with stock K ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
This is Hot side only.... Fits 2v GT with stock K member. Also fits 1996-1998 4V cobra with stock K member. Ok, I used the stock headers, the stock K member, a tial 44mm wastegate, and used a T-70 with a 96 ar housing which will be the turbo that I was going to run. The headers stay in the same spot they do NOT flip to the front of the motor.. The hot piping connects to the factory headers, merges to a y-pipe and passes under the factory k-member on the passenger side. The downpipe also passes under the k-member on the driver side and connects back to the factory catback.. With a 3" round Down pipe, and the car at stock ride heighth it gives me 3 1/2" or 4" of ground clearance. It has it's own "built-in" H-pipe you do not use a H-pipe so that saves you a $100 bucks right there.. ![]() ![]() S/X fuel system S/X 18203 pump Supports carbureted engines up to 1300 HP and fuel injected engines up to 1000 HP at 45 PSI Ultra high-flow rates exceed: 80 GPH at 12 volts and 45 PSI, AND 120 GPH at 12 volts and 10 PSI Flow-thru design maintains maximum cooling, produces outstanding reliability, and provides consistent fuel delivery from idle to full throttle -10 AN inlet/outlet fittings for easy installation For use with gasoline or alcohol fuel systems For race or marine use only Not for use with reduced sulfur content diesel fuel SX performance fuel pressure regulator 15402 Part Number: 15402 ( -10 AN inlets and port for fuel pressure gauge) Includes: mounting bracket and hardware (fuel line fittings are not included) sx fuel filter 41002 red fuel filter -10 in -10 out sx performance 41002 fuel filter -10 in -10 out with free - 10 hiflow couplers All fuel parts ar brand new.. Total Package price of $850.00 SHIPPING IS ENTIRELY ON THE BUYER PM me call him 316-871-8753(Nick) it will be going on ebay soon... |
its not going anywhere right away i dont think, so just have him pm me, or call nick about it (seeing as its his hotside)
give him a call, hes a good guy, was actually gunna start producing these kits for us 2v guys but ended up selling the car...
he called him and left a message just let him know 4point6 is a serious buyer and would like to work something out with shipping
01 GT manual-STOCK 97 GT automatic-SOLD |
i called him because i am very interested but i left a message and he has not called back yet
i left him a message asking what shipping will be to orlando area code 32824?
![]() It's Never Enuff |
Threads Similar to: turbo hotside for 96-04 gt
| Turbo timers and Boost Controllers? Turbo guys where you at? | 95StangSVT | Poweradders | 14 | July 11th, 2008 08:01 AM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | Poweradders | 24 | March 7th, 2007 10:07 PM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 11:05 AM |
| Turbo, Twin Turbo, Procharger, or Kennebell? | black94gt | 5.0 Mustangs | 19 | October 7th, 2006 11:41 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005+ | 9 | September 17th, 2006 05:15 PM |
