Lets Just Touch Tips.
91 fox
Pushrods91 90 To 91 LX.
==05/31/10==
SO I BOUGHT A 90 LX 5.0 IN THE FIRST OF THE MONTH. FOR $1000 JUST FINALLY GOT AROUND TO SOME PICS TODAY. ITS GOT A BBK CAI AND BBK SHORTY HEADERS.. I PUT ON A XPIPE I GOT FROM CHRIS (BLACK5.0) AND A SHIFTER I GOT FROM JEREMY (V8ONLY) TODAY. THANKS GUYS! LOVE THE SOUND WITH THE X AND FLOMASTERS. AND THE SHIFTER IS AWSOME. SO ANYWAY HERES SOME PICS OF THE CAR. ![]() ![]() ![]() ![]() ![]() ==09/03/10== so i havent done much here lately..but i did put the trans back in today and put on a new adj clutch cable and firewall adj and alum quadrent ... should gettin it off jackstands tomorow mourning ==09/06/10== Got me a alum driveshaft yesterday so i need to switch the yoke of mine to the new one...maybe today most likely tomorrow THANKS TO BOB!! 01yellercobra ==01/25/11== Been awhile since iv done shit. Well today i ripped the fenders off. I know i coulda took the whole front clip off but i didnt. I did it my way... one piece at at a time and it didnt cost me a dime.. Oh wait off topic. Anyways I figured it was time to rip in to the beast and get it up to par. Its been wrecked so the radiator support is bent to shit. So im gonna replace that and both fenders. Fenders cause i can. The radiator support cause it needs it. /end rumbleing... ![]() ![]() and the passenger side of the support. Its worse then this i just didnt feel like crawling underneath to get more pics. ![]() ==01/27/11== PROGRESS AT MY OWN SWEET TIME... ![]() ![]() ==02/13/11== Took the drivers door off. Put the new door on. Also just thru the front wheels on ima use for now... Not much but what i did today :shrug: ![]() ![]() ![]() ![]() Also fixed the door lock/unlock switch.... I love solder.. ![]() ==02/14/11== driver door all done.. and buttoned up... window works and locks work now... i iz happy![]() ==02/15/11== Yayyyyy new to me not broken tail lights.... Will paint em later.. ![]() ![]() ![]() ![]() ![]() ==02/24/11== So I broke the glass in the Gt hatch I was gonna use. So I took the lx wing of my car and started fillin holes. I cut up the gt hatch i had to use the metal to fill the holes. This is where im at now. ![]() ![]() ![]() ==03/24/11== Yesterday i got all the wireing fixed and run thru the hatch and thru the gt wing. Fixed and solderd what i drilled thru Wing is on and tight. All tail lights are on and work again. Never Knew what a 3rd brake light looked like. :look:==04/25/11== We started it Saturday.. Not a big deal considering we only did all the gaskets,oil pump and Timing Chaing for now.. But it runs and i had a boner.. Im excited to drive it again.. I got alot of stuff done to it i wanted to while it was down. Plus i got some other shit for it i havent put on it yet.. :look: Heres the 3rd start after we figured out we had 5 and 6 plug wires crossed BIG THANKS TO CHRIS FOR COMING OVER AND KICKING ME IN THE ASS WHEN I REALLY DIDNT WANT TO DO SHIT.. :high5: ==05/29/11== Did some stuff. Thanks to Chris for helping as always.. :high5: ![]() ![]() Yep.. been busy all my days off. Been getting stuff done. . I just need a adj fpr and ill be good for awhile. Chris hooked me up with a pump today. :==06/01/11== ![]() ==06/04/11== Tommy hooked me up today with a white fender. Much better then the blue one. Just need to do the. Door. ![]() ![]() ==06/21/11==
91 fox
==06/26/11==
Chris, Brett, and I got the new battery box all mounted up today as well as installed an aluminum driveshaft. ![]() ![]() ![]() ==07/05/11== I got a manual rack from Bobby and a sterring shaft. Put that in and remove ps pump and ac condensor. And run a 44in belt to bypass smog pump. 99% sure itll come off as well I ran my best of a 8.78 with a best of a 1.72 60ft. Im pretty happy with that.==07/17/11== Put 90/10s on and 4 banger springs in. Converted to a manal rack. Removed ac compressor and os pump and bracket. Also removed front bumper support and just put bumper cover in. Need yo figute out what belt i need then fire her up And thanks to Brett Chris And Bobby for making it a fun day. Even though Bobby blew the seals outta my jack. :look: :rofl: Gonna rape some bitches on the 30th :==07/25/11== ![]() ==08/20/11== There it is. Only the top right pulled away. Drilled some holes to pull it back in place. Then me in chris will make sure all is centerend and all proper n stuff. :look: then i weld it all up and brace the shit outta them ![]() ![]() ![]() ==08/21/11== Oh and i got a little something something else for the rear. :look: ![]() ==09/01/11== Here it is ready to go in. ![]() ==09/05/11== ![]() ![]() ==09/17/11== ![]() ![]() ![]() ![]() ![]() ![]() ![]() ==09/24/11== Welded in subframe connectors today. ==09/27/11== Down links done and tight. Not my.best bead but it was hot as hell so it SHOULDnt break. :rofl: ![]() ![]()
91 fox
RIP White Lighting!!! So this car is tottalled now. Hydroplaned acrros the freeway and hit the center mian. Everthing from this car is goin into my new to me 91lx. Picked it up for free. THANKS REN!! Just a shell. Had to take my K-memeber and rear axle out to make it a roller.
The aftermath!!! ![]() ![]() ![]() So after that I stripped it. ![]() ![]() Then I picked up the 91 for free from Ren. Only catch was it needed suspension to roll. So me n Chris headed to la and put my parts on it and brought it home. ![]() ![]() That was a month ago. From here to today. :-) Chris and I put it together ![]() ![]() ![]() Spent 2 hours buffing the paint out Tuesday. ![]() ![]() 4 pinned the.hood today. Bled the brakes. And few other misc things. ![]()
Glad you survived. Cool project man. More pics and progress.
Check my garage for pics and mods! ![]() Originally Posted by svtkidd23 if my gears were a vagina.. id beat it up! |
1999 Mustang GT
Wow... Crazy respect for you man!
91 fox
Thanks guys.
91 fox
Pick up some 4/10s in trade for some stock uppers and shocks. Going to install those this weekend or next.
91 fox
91 fox
Nitrous installed. Waiting for blow down tube and blow off valve to show.
Sent from my DROID RAZR using AutoGuide.Com Free App |
91 fox
Well hello parts!!!
91 fox
