LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build
Go Back   Forums at Modded Mustangs > Mustang Forums > Projects
Old December 7th, 2012, 02:28 AM   #1
lferg1's Avatar
2004 comp orange gt
lferg1 is on a distinguished road
ok so here it goes i started out in mustangs with a 99 mustang gt that got the full treatment motor transmission S/C fuel system blah blah blah. All was good and well but during the breakin miles a deer jumped out in front of me and totaled the car so good time to change the setup again lol i have problems making up my mind.
Ok so now the build thread begins i bought a 2004 comp orange mustang GT bone stock with 5000 miles and made the decision to destroy it
Motor:
Dss 5.0 stroker short block (built with an aluminum 3v block), with ARP 2000 rod bolts in H beam rods, main stud girdle and ARP main studs, forged pistons, Cometic head gaskets with Arp 2000 head studs and a moroso oil pan. Up top is 2v cylinder heads fully ported by dss racing with bronze guides, 1 mm oversized stainless intake and exh valves with crower springs, and crower stage 2 blower cams, typhoon intake manifold and bbk 78mm throttle body, MSD ignition coils.
Drivetrain: promotion built 3650 5 speed with pro 5.0 shifter. Clutch is a Centerforce dyad twin disc, rear end is still stock for now will be gone through after the car has been dynoed.
Fuel system: Return style with sumped tank,
Aeromotive A1000 fuel pump and Ford Racing 80lb fuel injectors.
Tuning: will be with an Sct handheld, and vmp blow through maf, N2MB wot box/2 step.
Power adder: Hellion twin turbo system with twin 61s
Suspension: Front is Upr full tubular front, and the rear is all stock until after the dyno
I have spent a fortune on this thing The build is still in progress 90% of the parts are already bought/in the process of ordering the only thing that im behind on is building the rear end ,sub frame connection and rear suspension, but all that will be finished before the car sees the track next spring.
Power wise im hoping for somewhere between 750 and 850rwhp on 110 octane and high boost.
Let me know what you guys think and ill post pictures soon so you guys can see the process/progress.
Old December 7th, 2012, 02:36 AM   #2
The Mean Green
MATT02GT's Avatar
MATT02GT is a name known to allMATT02GT is a name known to allMATT02GT is a name known to allMATT02GT is a name known to allMATT02GT is a name known to allMATT02GT is a name known to all
Sounds like a fun build, awesome color to work with also.. Be sure to post some pics!
Bolt on list in Garage...... MM Insomniac Crew
Old December 7th, 2012, 02:53 AM   #3
I love to skydive
Durr4456's Avatar
2005 Mustang GT, 1967 GT
Durr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud ofDurr4456 has much to be proud of
Subbed!
MM is awful. Don't ever come here if you haven't been sucked in already!
Old December 7th, 2012, 04:00 AM   #4
lferg1's Avatar
2004 comp orange gt
some pictures of the original build in my yellow 99, had a vortech and different clutch then and long tubes sold all of that after the wreck in favor of a stronger clutch and the tt setup i didnt take any pictures of it coming back out, but i will post more pics of the setup as it goes into the new car.
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-384738_2276957124546_1315970312_n.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-384169_2276957004543_856895905_n.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-378464_2276957404553_453904171_n.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-377655_2276956884540_1079042555_n.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-337034_2196792886660_1278405_o.jpg
Old December 7th, 2012, 04:03 AM   #5
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-336451_2350527249923_350470827_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-331300_2207195946730_7079220_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-329360_2297951615565_1658565683_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-326752_2196793566677_8007619_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-326201_2297952215580_656960454_o.jpg
Old December 7th, 2012, 04:09 AM   #6
lferg1's Avatar
2004 comp orange gt
the picture of the car on the ground with crazy wheel gap was from the weight loss from changing to the aluminum block, or at least that was the only thing i could figure.
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-325184_2297950735543_924682447_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-291576_2182957940795_2355023_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-291007_2236573161142_3112288_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-290544_2178708314557_4133498_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-290192_2178708554563_7538086_o.jpg
Old December 7th, 2012, 04:11 AM   #7
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-289586_2172079108831_1988627_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-288989_2297952895597_1104012157_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287910_2178707714542_6813573_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287814_2172080668870_2852622_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287714_2176875508738_4810673_o.jpg
Old December 7th, 2012, 04:12 AM   #8
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287691_2176876188755_5241186_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287408_2297949775519_1263946824_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-287129_2173783991452_1215921_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-286498_2158305044488_7219064_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-285971_2178706994524_7923300_o.jpg
Old December 7th, 2012, 04:14 AM   #9
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-243552_1999700679478_3151028_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-241512_1965312459794_2990957_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-220730_1858097939498_318853_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-220499_1873856053441_6605352_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-220461_1870038558006_5679965_o.jpg
Old December 7th, 2012, 04:16 AM   #10
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-220354_1870231642833_5292356_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-219731_1858097379484_4742315_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-219470_1858097059476_6426140_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-218742_1858098379509_6651619_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-209915_1858099659541_2526466_o.jpg
Old December 7th, 2012, 04:18 AM   #11
lferg1's Avatar
2004 comp orange gt
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-204741_1858098419510_6370459_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-204728_1858099019525_2166783_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-192961_2182953380681_1782788_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-192845_2171647818049_1052033_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-170776_1702161521185_1905277_o.jpg
Old December 7th, 2012, 04:19 AM   #12
lferg1's Avatar
2004 comp orange gt
sorry about the pictures being kinda out of order like i said this is what the car was before i tore it back apart and most of this stuff will be going in the new car
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-135149_1702162001197_440175_o.jpg
Old December 7th, 2012, 08:59 AM   #13
Resident Know-it-all
nxcoupe's Avatar
92 blk/blk coupe
9.70@140
nxcoupe has a spectacular aura aboutnxcoupe has a spectacular aura aboutnxcoupe has a spectacular aura about
Cant wait to see more.
90 GT 393 5 spd, 467 rwhp 480 rwtq > Sold
92 coupe, R/S 308 5 spd > Sold all engine parts off, coyote power coming soon..
93 coupe, 2.3 5 spd > still plugging along...
Old December 7th, 2012, 05:52 PM   #14
Figured it out
Austin_'s Avatar
2012 5.0
12.7@112
Austin_ is a splendid one to beholdAustin_ is a splendid one to beholdAustin_ is a splendid one to beholdAustin_ is a splendid one to beholdAustin_ is a splendid one to beholdAustin_ is a splendid one to beholdAustin_ is a splendid one to behold
+1 ^^
Old December 7th, 2012, 07:07 PM   #15
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
11.649 @ 119
Scott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud of
Sounds like a good build!
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Old December 7th, 2012, 07:32 PM   #16
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Nice build man! I'm building a turbo v6 stroker myself and used scat h beam rods with 3/8" arp2000 rod bolts.
There was aguy a while back that went 750rwhp with twin 54mm turbo's so you should have no problemb making 850rwhp with 61's. The guys name was dirtybird91 I believe.
Where you at in va? I'm in radford but work in Salem.
Turbo v6...4.3 stroker build in progress
http://moddedmustangs.com/forums/v6-...ker-build.html
Old December 8th, 2012, 02:47 AM   #17
lferg1's Avatar
2004 comp orange gt
I am actually friends with dirtybird we live in the same town
Old December 8th, 2012, 09:19 AM   #18
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
Good deal man, sounds like you'll know how to build em in your town lol. If you'll ever run those cars up this way or at motor mile dragway give me a shout.
Old December 22nd, 2012, 12:34 AM   #19
lferg1's Avatar
2004 comp orange gt
motors ready to go in except for port matching the runners and the turbos and intercooler are here, also the clutch came in so just waiting on the piping and front suspension from hellion supposed to be here next week
LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-332095_4746640431255_1598151283_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-474426_4718244921385_1018228485_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-478408_4746640231250_1473672232_o.jpg   LFerg1, 2004 Mustang GT, Comp Orange, Twin Turbo build-472868_4756046426399_375036592_o.jpg
Old December 26th, 2012, 09:45 PM   #20
slowmustanggt is on a distinguished road
I love the color on that clutch! heh nice build!
