Roanstang's build
Home Register FAQ Members List Calendar Timeslips Blogs Garage Gallery Auto Loans Search Today's Posts Mark Forums Read Auto EscrowInsurance
Go Back   Forums at Modded Mustangs > Mustang Forums > Projects
Old February 6th, 2013, 10:19 AM   #1
Hot rod Stang
audioAl's Avatar
2012 Mustang 3.7
14.00
audioAl will become famous soon enough
Roanstang's build
I am fairly new here, and just started my 2012 3.7 build. I am installing
BMR rear lower control arms & a J&M adjustable panhard bar. I will lower
the pony on sportlines and Eiback pro struts and shocks. Should I wait to
install the arms & panhard bar when I lower it or not? I'd like to see what
the bar & arms do for my suspension 1st.
"Roanstang" 3.7 DOHC Candy Red Metallic 2012 {RIP}
2014 DIB 3.7 w/ select shift/Yokohama 275/40/18's/Airaid "tube"& aFe Dry-S inverted/Boss strut brace/BMR lca's/UPR catch can/Koni sports/ J&M cc plates
  Reply With Quote Quick reply to this message
Old February 6th, 2013, 11:40 AM   #2
Authorized Vendor
BMR Tech's Avatar
BMR Tech has a spectacular aura aboutBMR Tech has a spectacular aura aboutBMR Tech has a spectacular aura about
Install them now. The PHR won't do too much for you right now, but the LCA sure will.
As for the springs, are you just choosing the Sportlines simply due to the way the car will sit? Are you wanting a handling car, or just good ride and traction?
Kelly Aiken - "The Ford Guy"
BMR Suspension Inc.
kelly@bmrsuspension.com
813.986.9302
CLICK FOR PROPER PINION ANGLE ADJUSTMENT!
CLICK IF YOU LIKE BMR SUSPENSION
Old February 6th, 2013, 05:36 PM   #3
Hot rod Stang
audioAl's Avatar
2012 Mustang 3.7
14.00
Thanks for the reply Kelly, I want a corner carving pony. I have thought about just
rear springs by BMR! Can you elaborate on the handling I'd get with stock struts & springs
if I just added a lowered rear spring setup?
Old March 7th, 2013, 05:44 AM   #4
Hot rod Stang
audioAl's Avatar
2012 Mustang 3.7
14.00
1 1/2" drop in rear
Update, I decided on Stack Racing rear springs 1 1/2 " drop which leveled Roanstang.
It handles much better now and no wheel-hop! Next is 3.55:1 gear & tuner. I'll post
pic's next week.
Roanstang's build-tn_nurse-cindy-009.jpg   Roanstang's build-tn_nurse-cindy-014.jpg   Roanstang's build-tn_nurse-cindy-024.jpg
Old March 18th, 2013, 09:55 AM   #5
Hot rod Stang
audioAl's Avatar
2012 Mustang 3.7
14.00
New pictures to come soon.
Human Verification
Forum is powered by vBulletin ©2000 - 2015, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
