Swift~Six's Build: 8 UR GT - Page 37 - Forums at Modded Mustangs
 16Likes
post #721 of 734 Old November 14th, 2016, 05:33 PM
2015 Ride Of The Year
Mach Stang!'s Avatar
*Sniff* we're like family already :,)
Buy My Car
-Rocco
Mach Stang! is offline
post #722 of 734 Old November 15th, 2016, 02:20 PM Thread Starter
Canon Gang
Swift's Avatar
Bay is painted! Next step is pulling the dash and installing the new column, PCM, harness, cluster, etc. Progress is going at about half the rate that it could due to building my buddy's turbo LS foxbody at the same time, but it's slowly getting there!
IMG_5071 by oh1slowsix, on Flickr
IMG_5070 by oh1slowsix, on Flickr
IMG_5067 by oh1slowsix, on Flickr
IMG_5058 by oh1slowsix, on Flickr
IMG_5052 by oh1slowsix, on Flickr
IMG_5078 by oh1slowsix, on Flickr
IMG_5081 by oh1slowsix, on Flickr
KS_Yeti and macuser27 like this.
Swift is offline
post #723 of 734 Old November 15th, 2016, 05:43 PM
SPECIAL TEAM FORCE
Austin's Avatar
daaaaannnnnnnnnnnnnnggggggggg
Swift likes this.
Austin is offline
post #724 of 734 Old November 16th, 2016, 01:43 PM
2001GTCraig's Avatar
Wow Swift! This build is absolutely incredible. Makes me miss my ol'e v6. I've spent probably the last day and a half during down time at work and it was really neat seeing the progression. Can't wait to see more updates on it!
2001GTCraig is offline
post #725 of 734 Old November 23rd, 2016, 04:06 PM
Looks good!!
Harris79 is offline
post #726 of 734 Old November 23rd, 2016, 10:49 PM
BrendanMilteer94's Avatar
Dude this thing is coming along so nicely. I saw on Instagram where you were installing the aprons. Looks sick man, glad I found your thread again so I could catch up on the progress.
2012 Race Red GT | Flowmaster Outlaws | Resonator Delete | BMR
Instagram @bmilteer94
BrendanMilteer94 is offline
post #727 of 734 Old November 26th, 2016, 03:51 PM Thread Starter
Canon Gang
Swift's Avatar
Got past a major milestone today. Pulled the dash and replaced the PCM, harness, booster, column, gauge cluster and pedal assembly with donor parts from the GT.
Untitled by oh1slowsix, on Flickr
Went to go connect the pushrod for the hydraboost... NOPE! slightly different pedal design for the V6. Pushrod comes through the firewall in a higher position with the GT's. Thankfully my buddy has a 2v shell in his yard and I was able to go nab the pedal assembly from his.
Got everything buttoned back up a few minutes ago. Now on to the motor!
Swift is offline
post #728 of 734 Old November 27th, 2016, 10:54 AM
MOAR BOOST
SlowSix's Avatar
How come you sold the kw coils and went to BC? Just going for the stance nation?
Turbo Build Thread
SlowSix is offline
post #729 of 734 Old November 28th, 2016, 12:43 AM Thread Starter
Canon Gang
Swift's Avatar
These BC's ride about 1000x better than the KW's.
Swift is offline
post #730 of 734 Old December 2nd, 2016, 05:52 PM
MOAR BOOST
SlowSix's Avatar
KW's too stiff? I know they are more of a racing coilover. What spring rate was on them, any idea?
Turbo Build Thread
SlowSix is offline
post #731 of 734 Old December 16th, 2016, 06:13 PM Thread Starter
Canon Gang
Swift's Avatar
Been relatively busy with work recently so haven't had a ton of time to devote to the car. Got a Pilot/TOB installed, a front/rear main seal, and an oil pan gasket also, and went ahead and mated the engine back up to the trans.
Then began tackling the harness. Went ahead and unwrapped the whole thing and will be doing something a little out of the ordinary with it. If it works the way I hope it will it should be super clean. Will update you guys on that again once the harness is modified and re-wrapped.
My SLP catback also came in. Have mixed feelings about it. The resonators and tips are gorgeous, but the tubing and hangers are awful. The welds on the hangers are atrocious and completely cold. Hangers are also crooked and seem to be mild steel. Oh well, I got a black friday deal on it, we'll have to work with what we got, and it'll end up being polished anyway.
IMG_5169 by oh1slowsix, on Flickr
IMG_5170 by oh1slowsix, on Flickr
IMG_5167 by oh1slowsix, on Flickr
Swift is offline
post #732 of 734 Old December 17th, 2016, 09:06 AM
Formerly whyxitx
HiMyNameIsWyatt's Avatar
iTrader: 8 reviews
Send pictures into quality control or customer service.. Those look like my welds. Lol. See what they can for you!
1997 Cobra - 4.10s , UPR x pipe , Magnapacks, Maximum Motorsports K Member, A Arms, C/C Plates, LCAs and Coil Overs. S/S Brake lines. Needs put together.
2006 Ninja ZX-6R
1991 Geo Tracker
1995 Wyatt
HiMyNameIsWyatt is offline
post #733 of 734 Old December 21st, 2016, 10:19 PM Thread Starter
Canon Gang
Swift's Avatar
So the harness is done, and installed. The majority of the engine harness now runs underneath the intake manifold in the valley. The injector and COP wires have been extended and now come through holes in each side of the manifold to reach the plug ins. The only real wires that are visible are the ones that run to the COP's, because the clocking of those connectors cannot be modified, the wires have no choice but to come out, make a U turn, then plug in. The injectors however have been clocked 180 degrees, giving the wires a shorter run to the connector, and a cleaner look
IMG_5895 by oh1slowsix, on Flickr
Harness cut, extended, and ready for wrap. For the wrap I used a dry vinyl cling tape, very similar to OE material, with a few adhesive tape wraps on the ends to keep them from unraveling. The harness has a total of 4 wraps of "sticky" tape, the rest is the dry cling vinyl.
IMG_5896 by oh1slowsix, on Flickr
As parts of the harness run through the valley, I knew heat would be an issue. The wire I used to extend the harness is 200C rated, and to further protect the OE wiring, I gave the parts in the valley a wrap of foil before being covered up with the vinyl.
IMG_5897 by oh1slowsix, on Flickr
All wrapped up!
IMG_5898 by oh1slowsix, on Flickr
Finished harness mocked up on the engine. I have a few things left to clean up and paint (as evidence by the alternator and IAC), but this is how the harness will look on the finished engine. Came out pretty slick!
IMG_5899 by oh1slowsix, on Flickr
Engine bay is getting less and less spacious by the day!
IMG_5902 by oh1slowsix, on Flickr
She just wants to go her beautiful, smooth, white home!
Swift is offline
post #734 of 734 Old January 17th, 2017, 12:42 AM
fastpony's Avatar
Send a message via AIM to fastpony
Damn!!!! I have missed a ton since i have been gone! lol awesome progress here bud!
fastpony is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/projects/303789-swift-sixs-build-8-ur-gt.html
My 2001 V6 Coupe Build Thus Far | SVTperformance.com This thread Refback November 22nd, 2016 02:01 PM
