Tuned Stock GT vs Bad Tuned Modded GT - Page 2
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner
Old January 5th, 2007, 12:45 AM   #21
1999 Mustang
Invictus is on a distinguished road
Originally Posted by Darrell
What you feel is in your head. Your mind is telling you that the engine is making more horsepower and getting better gas mileage because you are using higher octane because that is the extent of the education you have on the subject. However, that is not how an internal combustion engine operates. If you put it on a dyno you will see that you may have actually lost a few horsepower versus the lower octane fuel. Same goes for fuel mileage.
theres no way you're going to LOOSE power by upping the octane. you may not get anything out of it but itll act as a buffer against detonation if worst comes to worst. you may not get anything out of it on a factory tune but it wont hurt you
Old January 5th, 2007, 03:37 AM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Would you like to place a bet on that? We will run a stock 5 liter on a dyno. The first pull will be with 87-89 octane fuel. The second run will be with VP C16 race fuel. The engine will make less power with C16, I'll guarantee it. Internal combustion engines are most efficient when they are on the verge of detonation. Just enough octane so the engine does not detonate makes the most horsepower. That is a fact.
Old January 5th, 2007, 09:00 AM   #23
FaStStAnG5-0's Avatar
FaStStAnG5-0 is on a distinguished road
Send a message via AIM to FaStStAnG5-0
darrells got ya on that one... it is definately true... i spoke to my engine builder all about different octanes & what not when we rebuilt my sbc350 for my truck... plus i just would argue with darrel cause he knows his shit!!!
http://www.cardomain.com/ride/2461223
1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon!
Old January 5th, 2007, 01:59 PM   #24
1999 Mustang
ah, with c16 i could understand but 87 vs 93 same concept i guess but I just don't see a motor loosing efficiency with such a small octane increase. he was talking about using supreme pump gas on a stock tune which imo is fine. but you're right i wouldn't run 117octane gas on my stock tune either lol
Old January 13th, 2007, 05:13 PM   #25
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
I dont believe it's possible to make more horsepower on a higher octane fuel without doing some tuning and/or timing adjustments unless your vehicle is tuned and timed to run on that octane already. Otherwise, power benefits should be "VERY" slim to none..
Old January 14th, 2007, 01:05 PM   #26
The eaglenator is on a distinguished road
Mostly the extra power seems to be on take off only. So your not really getting more horsepower.
Offical MM Zepplineers crew member #4-Commander
Old January 14th, 2007, 03:47 PM   #27
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
Darrell is 100% correct on this one. I was a tech at a GM stealership years ago and we had a guy from BG come in one time to do a demonstration on fuel systems and octane for us. Did you also know that the lower octane fuels burn cleaner than the higher octane fuels? The higher octane fuels have more carbon in them therefore leave more carbon deposits when burned which makes it more likely to start "labor knocking", fouling plugs and leave deposits on your valves which, over time, can keep them from performing properly.
Threads Similar to: Tuned Stock GT vs Bad Tuned Modded GT
Stay Tuned JASonic The Clubhouse 27 October 19th, 2007 10:11 PM
vid of car after being tuned sonicblue Videos 3 May 27th, 2007 06:46 PM
Tuned Up MustangMo V6 Mustangs 14 May 16th, 2007 08:15 PM
finally tuned slow98gt 96-98 14 April 27th, 2007 07:34 PM
Is my car tuned? jagermiester 99-04 7 February 20th, 2007 08:09 PM
