UMI New Product Release- Heavy Duty Billet Sway Bar Mounts
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > UMI Performance
Old September 10th, 2010, 02:32 PM   #1
Authorized Vendor
UMI Performance is on a distinguished roadUMI Performance is on a distinguished road
Talking
UMI Performance Inc.
Heavy Duty Billet Aluminum Sway Bar Mounts
Starting at: 89.99/set
These heavy duty sway bar mounts from UMI are CNC machined from beautiful T6-6061 billet aluminum and are nicely sanded with a clear finish to prevent corrosion. Large sway bars place a lot of stress on their mounting points and mounting brackets causing them to flex, bend or even break. These heavy duty aluminum mounts are a new replacement for the stamped steel mounts supplied with most aftermarket sway bars. The UMI brackets are supplied with new greaseable polyurethane bushings and grease fittings. Not only do these brackets reduce flex they offer a great touch to the underneath of your vehicle. Price is per set, one set needed for one sway bar.
Sizes available- 7/8" (22mm), 1" (25mm), 1-1/4" (32mm), 1-3/8" (35mm)
Ryan
UMI Performance Inc
www.umiperformance.com
ryan@umiperformance.com
814.343.6315
Join us on Facebook!
Threads Similar to: UMI New Product Release- Heavy Duty Billet Sway Bar Mounts
How do you break a Steeda Heavy Duty rear sway bar...? Put it on a V6 Mustang. buddyantunez1 99-04 22 November 20th, 2011 11:55 PM
Installig CHE UCA and Heavy Duty mount mustang fanatic 2005 - 2010 1 November 29th, 2008 11:30 PM
New Product Release From BBK!! Derek@DRI 99-04 28 August 18th, 2008 11:31 PM
