Authorized Vendor
![]() Join Date: Sep 2009
New Product from UMI- 2011-2012 Ford Mustang Adjustable Rear Upper Control ArmExtreme Duty Rear Upper Control Arm for the 2011-2012 Ford Mustang P/N 1066 Starting at $119.99/each UMI Performance is pleased to announce the release of an adjustable rear upper control arm for the 2011-2012 Ford Mustang (P/N 1066). Upgrade from the flimsy, factory rubber bushing setup to improve responsiveness and reduce wheel hop upon launching. The robust, reinforced bracket is constructed from CNC machined 0.250” thick mild steel and reinforced with three-hole gussets for incredible strength. Premium rod ends allow for smooth articulation without the binding associated with the factory rubber bushings. The P/N 1066, with its on-car adjustability, allows you to easily set pinion angle for drag racing applications or correct pinion angle to compensate for vehicle lowering. The beautiful red or black powder coated P/N 1066 uses factory hardware and will allow you to harness the power of your new Mustang. Proudly designed and fabricated in Philipsburg, PA – USA. Application: 2011-2012 Ford Mustang V6, GT, GT500 Website Link Here P/N 1066 ![]()
Ryan UMI Performance Inc www.umiperformance.com ryan@umiperformance.com 814.343.6315 Join us on Facebook! |
Threads Similar to: New Product from UMI- 2011-2012 Ford Mustang Adjustable Rear Upper Control Arm
| BMR Launches New Product - Upper Control Arm for 2011 Mustang (UTCA030) | BMR Tech | 2011+ | 12 | April 12th, 2011 12:21 PM |
