octane
Old December 5th, 2008, 11:18 AM   #1
riddlee josh's Avatar
1998 mustang 3.8l v6
riddlee josh is on a distinguished road
octane
how come my tuner only alows me to select 87 91 and premium octane for my tune. it won't let me select 93 or 100.
is there a reason why?
i have an xcal 3 it was unlocked when i got it. i bought it used from here.
RACING
because baseball,basketball,
bowling,football, and golf only
require one ball
Old December 5th, 2008, 11:23 AM   #2
2008 GCSRT8, 1965 Coupe;
rwboring is on a distinguished road
i dont know but 87 91 AND premium sounds like premium is 93 IMO
Old December 5th, 2008, 11:26 AM   #3
well i was at bp and they had 87 93 and premium to select from. i was going to try some 91 octane but the bp did have it all they had was 93 so i went ahead a got the 87.
RACING
require one ball
Old December 5th, 2008, 11:27 AM   #4
that doesnt make any sense? why not just get 93 then?
Old December 5th, 2008, 11:29 AM   #5
because my on my tuner i only can select 87 91 and premium. so i didn't want to get an octane that i couldn't match with my tune.
RACING
require one ball
Old December 5th, 2008, 11:33 AM   #6
you can go better... but you dont ever want to just put a 91 or 93 tune in and go straight from 87 to 91 or 93... BECAUSE even if that needle is on empty you still have a few gallons left... you need to keep the tune down and run a tank through and stop changing what you run all the time....
Old December 5th, 2008, 11:37 AM   #7
i have my car tuner for 87 as of now but i was going to try 91 just to see if i could tell a dif. but when i went to go get 91 bp only had 93. so i am running the correct gas for my tune but i was just wondering why i can't select 93 octane on my tuner
RACING
require one ball
Old December 5th, 2008, 01:16 PM   #8
like i said before if it has prem on the tuner that is probably 93... sometimes BP and sonoco call prem 94... but dont put the tune in till you run a tank through... just go somewhere else and get gas
Old December 5th, 2008, 02:17 PM   #9
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
premium is 93. its what i was running in my car.
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
Old December 5th, 2008, 02:19 PM   #10
Lt_Crazy is on a distinguished road
^^^ wow u only have 2 tunes.....my Xcal 3 came with an 87, 91 and 94 tune...im currntly running the 91...
The difference between Fiction and Reality???
Fiction has to make sense.
-Tom Clancy
Old December 5th, 2008, 02:27 PM   #11
MustanG_guy17's Avatar
2007 Mustang GT/CS
MustanG_guy17 will become famous soon enough
Fill up with 93... run the tank to empty.. Fill up with 93 again. Then Tune your car for 93-87 octane, you can run a 91 octane tune and fill up with 93.. Just never go lower then the octane your tuned for. You can always go higher.
2007 Mustang GT/CS 5spd: Flowmaster hushpower axle back,O/R X pipe,JLT CAI,93 Bama tune..laser interceptor dual jammers, Escort Redline RD,Laser Veil G4.
MAVERICKS!!!!!!!!!! BABYYYY.. DALLAS COWBOYS
Old December 5th, 2008, 02:31 PM   #12
Fashion Guru
me?
I love 93hatch
Old December 5th, 2008, 03:52 PM   #13
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
93 is premium, on your tuner, and 100 cant be selected cause you dont have the tune
NCMM #9
Old December 5th, 2008, 05:54 PM   #14
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
+1 you can tune to any octane, but you'll need a custom tune to do it. click on the link in my sig and Joe can help you out. Also at MOST gas stations 93 IS premium. I have my car tuned to run 93. However, I was actually running premium for a few months before I got the tune, so I was sure that all the fuel in my system was 93 oct. BTW, if I were you I wouldn't even consider going above 93 with your current setup. Once you have done a bit more you can consider going higher, but then you'd have to kiss pump gas goodbye.
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old December 5th, 2008, 10:50 PM   #15
can i advance my timing slightly with higher octane gas? i thought i had read something about being able to advance the timing slightly with a higher octane
RACING
require one ball
Old December 7th, 2008, 02:01 AM   #16
blackmustang98_ is on a distinguished road
i have the same question
Old December 7th, 2008, 12:02 PM   #17
SleeperStang88's Avatar
2000 Mustang V6
need to run at track
SleeperStang88 is on a distinguished road
i think that you can , but you dont want to raise em any higher than +1 or +2
Old December 7th, 2008, 12:42 PM   #18
how come no higher than that?
RACING
require one ball
Old December 7th, 2008, 09:57 PM   #19
2000 Mustang V6
because your car is not built for it, you would need a motor that can handle it...........this is wat im told cuz i had the same question
i raised my buddies by +1 all across the rpms and +2 globally oh and only raise em if you keep your octane higher keep it at 91 or 93 trust me it makes the difference...the timing that is....itll feel a good amount more powerfull
Old December 8th, 2008, 11:17 AM   #20
yea i have mine moved up slightly with an 87 tune and it made a big dif. that is why i am kinda excited that gas is cheap and i can use a higher octane
RACING
require one ball
Threads Similar to: octane
87 Octane blackhavok 2005 - 2010 56 April 13th, 2008 10:10 PM
93 octane 07gtmustang 2005 - 2010 7 February 18th, 2008 08:12 PM
93 Octane? tsp_2177 V6 Mustangs 14 December 13th, 2007 11:43 PM
93 Octane BWAL 5.0 Mustangs 16 November 15th, 2007 06:37 PM
93 octane? petrol_head 5.0 Mustangs 9 July 16th, 2007 08:12 PM
