Testing the MAF
Old December 8th, 2008, 05:26 PM   #1
Dragonhunt is on a distinguished road
Testing the MAF
I have a 2000 Mustang 3.8 V6 Automatic.
Is there a to Test the Mass Airflow Sensor?
If so, please explain or give me a link to a How to.
Thanks
Old December 8th, 2008, 05:27 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
what do u mean test it?
SCT Mass Air Flow Sensor $200
Old December 8th, 2008, 05:30 PM   #3
I have heard that if you unplug it and rev the engine....something is suppose to happen.
Thanks
Old December 8th, 2008, 05:31 PM   #4
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
Thanks
yea somethin will happen, ur engine will run like shit. but i've never heard of testing ur maf
Old December 8th, 2008, 05:50 PM   #5
Ok,
I had the car in park. I unplugged it, and took the engine to like 3,000 RPM. Then I plugged it back in and it sounds the same.
Any thoughts?
Old December 8th, 2008, 06:13 PM   #6
Stang187 is on a distinguished road
One day I was cleaning my CAI and put it all back together into the engine and forgot to plug my MAF back in. I rode around for 3 days without my MAF plugged in like an idiot. Wondering why my car feels like its braking by itself when letting off the throttle and why my CEL was on. I figured it out finally, and called myself a nuckle head. So basically nothing except your car will feel different when braking, and shit gas mileage.
Old December 8th, 2008, 11:11 PM   #7
stephen has a spectacular aura aboutstephen has a spectacular aura about
The MAF has a heated wire inside. The temperature of the wire depends on air flow over it and the resistance of the wire depends on temperature. The calibration would be done by measuring the wire resistance at different flow rates. This would require some apparatus for measuring the flow rate. About the only test you could do yourself would be to measure the wire resistance cold to be sure the wire isn't broken. An alternative is to swap the MAF for a rebuilt one that has been calibrated.
Old December 9th, 2008, 12:36 PM   #8
I will test it with a multimeter and a can of compress air(this should change the air temp. I am going to start testing everything on the car. Air Temp Sender, MAF, Cam/Crank Sensors, All Pollution devises and everything else until I figure this out.
The car stumbles bad between 1200 and 1700 PRM's
Any other things I should consider?
Old December 9th, 2008, 12:48 PM   #9
Glorious PC gaming master race
graystang01's Avatar
2003 Audi A4
boats & hoes
graystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to beholdgraystang01 is a splendid one to behold
Send a message via AIM to graystang01 Send a message via MSN to graystang01
what exactly are you trying to figure out here?
MILITARY CREW - USAF E-4
Originally Posted by thrasher! View Post
You know you can do better. I'm not going to just let you settle for every little Asian that glances her squinty little eyes your way.
Originally Posted by mr.burton View Post
I was on my knees for 2 hours today
Elmo187 loves 8==D
Old December 9th, 2008, 12:50 PM   #10
snoel123 will become famous soon enough
Test the voltage coming off your maf sensor, should be .8 volts at idle. (800 rpm) Also inspect the wire visually to ensure they are not dirty as this will cause them to be insulated and give false readings. Be sure to backprobe the wires (HINT paperlip unfolded works well) with the sensor connected. Alot of things could cause this ignition system and fuel system would be where I started. I always check fuel pressure first as it is very easy.
Certified Master Technician
Also FORD certified
-Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist.
Old December 9th, 2008, 12:55 PM   #11
There are several wire in this connector and you will probably want to get a wiring diagram to ensure you are probing the right wires. Note the IAT is usually incorporated in the MAF so some MAF sensor connectors may have 4-6 wires running in them. The MAF itself has 3 wires VREF, SIG and SIG RTN. If you do not understand what these are for I would not suggest probing any circuit on your car until you educate yourself some more. I don't mean to be harsh but you could spend alot of time and money to solve the problem.
Also FORD certified
Old December 9th, 2008, 01:36 PM   #12
Hey,
First I would like to say thanks to everyone for the help/thoughts on this issue.
This is what I do know.
1. I have cleaned the Air Temp Sensor, MAF sensor with sensor cleaner
2. New spark plugs from Ford (SP486) gaped at 054, New JBA 9mm ignition wires.
3. New PCV Valve
4. New Fuel Filter
5. New Air Filter
6. My car has the good rocker covers (the ones that has the plate built in so the oil does not splash directly onto the PVC Valve from the rocker arm)
I have the Hayes Manual that I will you to test the things below.
What I have not done is:
Test the ignition coil ( I heard they go bad)
Test fuel pressure.
Test Cam/Crank Sensors
Test all pollution devises.
Have I covered most of it?
