2002 V6 Mustang
2002 How to remove window control switch housing?
Does anyone have a picture (or simple explanation) of the lower clip on a 2002 drivers side window control switch housing (the plastic trim panel covering the window and door lock controls)?
I need to remove it to check the power lock switch (drivers side unlock switch doesn't work). I can pop the top clip out but I'm cracking the plastic as I try to get the bottom one off because I don't know how to release it. thanks for your help |
!FACEPLATED!
its just a clip. if you get something under it, it will pop up. where are you from?
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2002 V6 Mustang
Thanks. Fairfax, VA
The piece is cracking on top instead of popping off. |
!FACEPLATED!
Whats the temp there? The plastic gets pretty brittle when it gets cold. Your best bet would be to do it in a heated garage.
2000 Mustang V6
need to run at track
![]() iTrader: 2 reviews
+1
do it in a a warm area and pull up on it hey performance, where are you located in michigan? |
!FACEPLATED!
Menominee, its the lowest point of the U.P. I'm about an hour north of Green Bay, WI.
¡ʇsnq ɹo uʍop ǝpısdn
the top needs a screw drive pried in and then you just push down on it, the bottom just pulls up. now be careful putting it back in and don't force it too hard, i snapped part of the clip that holds it in.
Threads Similar to: 2002 How to remove window control switch housing?
| Window switch GONE | Bhblondguy | 2005 - 2010 | 5 | October 24th, 2008 06:41 PM |
| window switch | 06SuperStang | 2005 - 2010 | 13 | September 28th, 2008 09:24 PM |
| Window Switch? | 06SuperStang | 2005 - 2010 | 8 | August 13th, 2008 03:06 PM |
| rear axle housing switch | Toph6888 | V6 Mustangs | 10 | February 7th, 2008 12:48 AM |
| window switch | barksdaleammo | General Tech | 31 | May 23rd, 2007 09:33 PM |
