EGR system - Page 2
Old December 11th, 2008, 04:52 PM   #21
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by a_kraker99 View Post
Cant you just cut it off with a cutting torch or something? You have to weld it shut anyways right?
Question: I plan on getting a tuner sometime in the future but I might want to remove the EGR before that. Is a CEL light the only problem I will have or are there other issues that it causes?
Did any of you see a MPG drop when removing it? Also, I heard that the EGR was necessary to keep engine temps down when cruising for long periods of time. Anyone having trouble with high temps?
u can, but most people just unscrew it from the pipe and screw on a cap...
SCT Mass Air Flow Sensor $200
Old December 11th, 2008, 04:55 PM   #22
2003 Mustang V6
a_kraker99 is on a distinguished road
Does the cap come with the delete kits?
Also, it looks as it from where the egr is located it would only circulate the gases 2 the nearest 2 cyliders.
Old December 11th, 2008, 07:12 PM   #23
stephen has a spectacular aura aboutstephen has a spectacular aura about
If I took the time to actually look at the parts I am talking about maybe I wouldnt ask such dumb questions. I can see now that the EGR has nothing to do with the TB. Anyways, what causes the carbon buildup on the TB? It cant be the breather hose can it? Air should be flowing into the breather, not out of it.
I believe blow by gases flow from the valve covers to the intake air tube through the breather tube. There is also some oil that goes through that hose into the intake in spite of the baffles in the valve covers.
Old December 12th, 2008, 07:16 AM   #24
2003 Mustang V6
The PCV side should be the one venting the gases though. Isn't the breather only there to let fresh air into the crankcase?
Old December 12th, 2008, 07:08 PM   #25
Could be right. The left valve cover has the PCV valve and is connected to the intake manifold. The right valve cover connects to the intake. So maybe air is flowing from the intake into the crankcase through that tube.
Old December 12th, 2008, 07:12 PM   #26
2003 Mustang V6
Thats how I always under stood it to work anyways. Otherwise if you are just venting positve pressure you would really only need the PCV valve. I think the valve/breather combination circulates some clean air through there.
Threads Similar to: EGR system
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 14 May 1st, 2011 02:17 PM
EGR VS EGR delete? riggsracin 94-95 5 December 14th, 2008 11:56 AM
EGR all5.0motor 94-95 9 October 23rd, 2008 01:39 PM
Traction Control System (TCS) and Anti-Lock Braking System WAR-PARTY 99-04 11 June 18th, 2007 07:56 PM
Cold Air Intake System/Shaker System Bish Audio/Video 11 June 15th, 2007 11:04 PM
