oil in coolant
Old December 15th, 2008, 12:37 AM   #1
1995 Mustang GT
slower than a 3 leg dog
efulton95 is on a distinguished road
oil in coolant
my friend has a 96 v6 and we think he might have blown a head gasket but arnt possitive. There was clearley a blown hose but the thing we are confused about it there is oil in the coolant resivoir. the hose that blew was a coolant hose not oil. I have heard it could be any of the following, head gasket, intake gasket, or timing cover seal, does anybody have an idea? We put a new hose on it and there doesnt seem to be any major leaks but the oil in the coolant makes me think something had to break internally. any input would be appriciated and if i was wrong about anything please correct me. thanks
Old December 15th, 2008, 01:44 AM   #2
¡ʇsnq ɹo uʍop ǝpısdn
drain all the coolant and see how bad it is.
you are right on with all the potential problems but with out much knowledge your guess is as good, if not better then mine. good luck, keep us posted.
Old December 15th, 2008, 01:56 AM   #3
Nitrous Injected's Avatar
2003 Mustang GT
13.987@100.98 MPH
Nitrous Injected is on a distinguished road
yea man , dran your coolant and your oil as well. If you have kind of a milky oil then there is coolant in the oil...you hole oil in the coolant??? never seen that before, but keep me posted i might learn somthing?
88 NOTCH,351 WINDSER,BUILT C6 TRANY,750 CFM CARB,4:30 GEAR=??? WWIII
2003 MUSTANG GT SOLD with 488 RWHP and 520 FT-LB on 150 shot and bolt ons R.I.P.
Old December 15th, 2008, 08:01 AM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
Oil in the coolant is a bad sign. Yes it could be a head gasket, lower intake manifold gasket, or front cover gasket. Did it overheat when the hose blew? If so it's likely a head gasket.
Old December 15th, 2008, 08:11 AM   #5
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
I say cracked head or block.
www.1fun4rd.blogspot.com
Old December 15th, 2008, 09:00 AM   #6
1995 Mustang GT
there is oil in the coolant but no coolant in the oil. and we drained the coolant and there was maybe a 1/4 of a quart of oil if that. unfortunatly i dont think we will know until we tear it down. and yes it did over heat when the hose blew. we are starting to lean tward the heads but arnt sure yet.
Old December 15th, 2008, 10:32 AM   #7
I'm not sure if 96 had the multilayer steel (MLS) head gaskets. The gaskets that were used in the earlier V6 engine had problems. Since it overheated it is almost certainly a head gasket. While the heads are out have them checked for cracks and surfaced. Also check the mating block gasket surface for straightness. The MLS gaskets require a very smooth surface to seal. The machinist should know about that.
Old December 15th, 2008, 10:46 AM   #8
It would be a good idea to also replace the timing cover gasket as well.
Threads Similar to: oil in coolant
oil in coolant but no coolant in oil? jtyson8602 5.0 Mustangs 14 October 23rd, 2008 08:47 AM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 01:17 AM
location of oil pressure switch and/or coolant sensor on a h sweet99 99-04 2 March 23rd, 2007 07:12 PM
oil in my coolant kdawg48_2000 V6 Mustangs 2 August 6th, 2006 11:18 PM
oil in my coolant kdawg48_2000 General Tech 2 August 5th, 2006 09:08 PM
