dome light
Old December 15th, 2008, 01:04 PM   #1
Triple A's Avatar
Triple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud of
dome light
what is the correct bulb?
my car didnt have one when i bought it and its getting annoying
Old December 15th, 2008, 01:49 PM   #2
Triple A's Avatar
nvm
Old December 17th, 2008, 04:52 PM   #3
Prankster's Avatar
2003 Yellow V6 Coupe
Bone Stock just tires
Prankster has a little shameless behaviour in the past
That's because that darn light just would not go out when the door was closed.
So, when you get the bulb installed be sure you spray a lot of WD-40 inside the door latch to fix the problem.
Loki
Old December 17th, 2008, 05:40 PM   #4
Triple A's Avatar
it works fine
Threads Similar to: dome light
map light/dome light bulbs 00gtv8 Audio/Video 4 May 4th, 2008 10:30 PM
Dome Light Won't Go Out? Schraders 99-04 12 January 2nd, 2008 04:11 PM
light bulb in dome light myeleanor 2005 - 2010 7 August 31st, 2007 03:34 PM
Dome Light Murderjetz Audio/Video 2 June 21st, 2007 08:55 PM
How you can change your dome light color. (light on roof) SonicStang Visual 25 March 23rd, 2007 12:39 PM
