2003 Mustang V6
Squeaking suspension
What is the most common cause of a squeaky suspension on an 03 Mustang? I am not 100% sure but I think it is coming from the rear end. It does it on even minor bumps in the road.
Do I have any grease fittings on my car or is it probably something that just needs to be sprayed with some grease? If so can someone post a picture of where I need to spray? My knowledge of suspensions so far is very limited so take it easy on me. Also, the temps here got down to about 15 degrees today and I had a different squeak that happened during every tire rotation until it got warmed up. |
Abyssinian of AX
'02 Saleen
19.34@42.259
You don't know suspension?!?!?....Get 'em, boys. !!!!!
![]() Sounds like may be bushings or rubber parts around rear end connections in need of lube or failing. Easiest thing to do would be to bring to a good local tire shoppe and have them lift it up and check it out. They can hook you up wit da grease gun and prolly fixer up good, pardner. Could be some other stuff, but they can figure it out quick HTH Jazzer
Resident DJ
'01 Cobra Vert.
Play nice Jazzer; not all of us sleep with suspension parts
. I'm going to 2nd Jazzer here with the shop. Throw her up on a lift and see what's crackin'... I'm leaning towards a bushing needing to possibly be replaced
2003 gt
5.4 32v on the way
How many miles are one it, when does it squeak, do you know for sure its from your rear?
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
2003 Mustang V6
105,000 miles. I dont know for sure it is the rear but it seems to squeak when the rear is going over the bumps.
Resident DJ
'01 Cobra Vert.
I'd start with bushings and have them checked out...
2003 Mustang V6
Whats a normal price for a place like belle tire to charge for lubing everything up?
Resident DJ
'01 Cobra Vert.
Shouldn't take more than an hour...so shop rate an hour x 1hr.
Moderator
2003 Grand Cherokee
Mine squeeks also. It's coming from the back right area. I only have 48,5xx miles. I need to jack it up and take a look. Would be interesting to know what the OP found w/ theres.
It would be nice to have an idea of what he did before I start on mine as I also am not well educated w/ suspensions. But I learn from taking things apart so I should be semi-educated after this.
ttt
2003 Mustang V6
huh?
2000 V6
![]() iTrader: 1 reviews
Does some one need to learn how to search? Or is zippy trying to be cute?
Silver Vehicle Club Member #4
2003 Mustang GT
N/A
Mine does the same thing too but only when i turn quickly and the car somewhat leans to one side. im not all that sure about suspensions either but i would have them check the bushings or something rubber back there. i know that when i turn my steering wheel there is a small rubber part on it that squeaks and sounds like its popping kinda also and i cant fix with grease =(. so if it is a rubber part then you may have to completely replace it.
NCMM Founder ![]() NCMM -- Check it out and join us! PM White03v6 or myself if interested in joining NCMM. RIP 04 v6... Hello 03 GT
Threads Similar to: Squeaking suspension
| Squeaking... | weems | 4V / SVT | 9 | April 3rd, 2008 08:09 AM |
| Squeaking | I_eat_rice | 99-04 | 4 | July 21st, 2007 02:37 AM |
| squeaking | xedubx | 99-04 | 4 | July 15th, 2007 10:34 AM |
| Squeaking suspension | Mystry | 96-98 | 2 | May 2nd, 2007 05:35 PM |
| Squeaking GT! | dmachine22 | 99-04 | 3 | March 25th, 2007 07:25 PM |
