Crusie Control
is there a way to adjust the crusie control cable?
what do you mean by adjusting the cruise control what do you want to do
make it longer
Selling Mustang So Im Selling All M112 Parts |
#4 | |
1999 Ford Mustang V6
14.79 @ 92.15
i just need like quarter of an inch if that i mean i can fit it on there but then it holds back the throttle body and then it idles at 3000 rpms
#6 | |
14.79 @ 92.15
Zoolander
04 Cobra #2260/3768 1/820
what speeds are you setting it at? Does this happen at all speeds? The car doesn't shift when you set it? Seems to me under normal driving conditions that it would shift into a higher gear to save gas.
Threads Similar to: Crusie Control
| steel control arms vs aluminum control arms | Saleenwolf720 | 99-04 | 1 | October 15th, 2007 02:32 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 12:45 PM |
| Hampton Roads crusie to VMP for the FFW | nem | 2005 - 2010 | 2 | June 22nd, 2007 07:48 AM |
| Code P1443 Evaporative Emmision Control System Control Valve | jagstang96 | 96-98 | 10 | September 5th, 2006 08:26 PM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 02:45 PM |
