Trouble code help
I just got my car back from having to blown heads replaced. Check engine comes on and the code is P1407. It means no flow of EGR I understand. What is the solution to the problem? New valve? Where should i start? TIA
Billy |
1999 Ford Mustang V6
14.79 @ 92.15
what year mustang?
check to be sure the EGR pipe is connected at the header and at the EGR vavle. check the 2 rubber hoses as well. if the vaccuum lines are sealed and the EGR valve is bolted to the block, check the electrical connector at the valve too. got any pics of the engine bay? we may be able to see if something is awry or an easy fix before really jumping into it...
its a 95 v6. im gonna check on it in the morning as it is dark now. will try to post a pic also. thanks
14.79 @ 92.15
good deal. if you could get a pic of the motor up, we could eliminate any easy fixes and help you from there. welcome to MM btw
sorry a day late. i tried to get send some pics from my phone to my email but it didnt work. i inspected all connections and seem to be correct. i attached my vacuum pump to the valve and it held pressure. it even made a sound when i took it off assuming the diaphragm is moving. tommorow i was gonna check the other hoses for vacuum and go from there. any advice would be appreciated. TIA
Billy |
well my two pics came through on my email but they are .bin files and cant be posted. i can open them with windows picture and fax viewer. could i possibly email them to you? i see your in evans. im just across the water in aiken.
today i checked the hoses and electrical connections for voltage. i followed the procedures in my haynes manual and if u have one i did whats on page 6-18 and 6-19. in section 5 i did line 9, 15, 16, and 17. all checked out ok. the 18th line i couldnt quite figure out what they were saying. anyway, i need to know if the lines are hooked up correctly to start with that may be the problem. there is the pipe from the exhaust manifold to the egr valve. the first hose from the botton of that pipe goes to the backside of the DPFE sensor, the side opposite of the electrical connection. the next hose up goes to the front side of the same sensor on the same side as the connection. also from the manifold vacumm port there is a red hose that goes to the bottom port of the EVR, and from the EGR valve there is a green hose that goes to the top port of the EVR. are the hoses in the correct sequence? TIA
Billy |
anyone??
no clue buddy. gona have to wait for AB
Threads Similar to: Trouble code help
| Trouble Code P1413 | Mrs_Mustang | V6 Mustangs | 36 | December 1st, 2010 06:46 PM |
| trouble code p1495 | DragonFreak | 96-98 | 5 | August 18th, 2007 11:02 PM |
| trouble code | 00vabchgt | 99-04 | 5 | April 17th, 2007 04:57 PM |
| Trouble code | dezzrat1 | 94-95 | 0 | April 17th, 2007 09:36 AM |
| Trouble Code | pdg36 | V6 Mustangs | 1 | March 29th, 2007 07:35 PM |
