1999 Ford Mustang V6
14.79 @ 92.15
Drag radials
ordered a pair of BFGoodrich g-Force A/T drag radials today. 315/35/17. i will let you know how they perform on the street and at the strip once i have them mounted and balanced later this week or early next...
#2 | |
WOOT WOOT! go ab! cant wait to see your times now.
bout time!
I havent seen more than the old shadow of your rear tread in about a month abnd a half! lol
God... That Euro import guy is really starting to get on my nerves... my car can only beat his in a strait line(maybe)
whens the last time you went to the track anyway?
14.79 @ 92.15
havent been in almost 9 months! lookin for a solid mid 14 second time at about 92ish now
¡ʇsnq ɹo uʍop ǝpısdn
... you could do better then that... ditch all the wieght that you have left in your car... and make sure you leave the girl at home too
dead weight imo
with about 220-230hp i'll take mid 14s
14.79 @ 92.15
im leaving it in full trim with the sub and amp... shooting for 14.7... if i trap 92, i am happy. not too shabby for 104k miles and everyday trim...
yea if you ran 14.7 you know that if you took out everything at best you'd get 14.5 so weight wont be a huge issue
i'd be happy with 14.7 @ 92 with that power the car has
at only 220 hp u think you will even see much of a difference in time from ...275s u have in the rear correct? i would bet lighter rims and scrifcie grip would get you better times. would be interesting to try them both
96 GT , cams,intake manifold,CAI,Exhaust,Full Hotchkis suspension, and many more |
well yea people put drag tires on stock rims and run better times then with heavier rims
yes but clearly he doesnt have stock rims at 315
lol well yea im just saying its a good idea for better times
ok i get what your saying, but im curious since he only has like 220 hp and probably less TQ down low being a 6, i would be curious to see if stock rims and tires would get him a better time verse those huge heavy ones even tho they have more grip. the grips good only if you can exploit it
Zoolander
04 Cobra #2260/3768 1/820
wheels aren't heavy though. They are pretty lightweight. I don't see why people act like wheels are so heavy, yea they may slow you down a little bit, but not that much. He has 17x9 all around. We may not have as much as torque as an 8 but we have a nice bit of torque. Enough to throw you back in the seat a couple times.
14.79 @ 92.15
i have 17x9 front which is a lot of parasitic drag on the road and considerably slows me down. i was considering a 15x5" wheel up front, but i drive the car Everyday.
i have 17x10.5 rear which is the same rotating mass as stock and they are the driven tires to size is only for traction. at 315mm, i have 12.4015748 inches of tire size. not all of this will touch he road at 40psi, but at 15psi, it should hook much better and cut my 2.23-5 60' down to a 2.1x and give me the edge on my mid 14 e/t. it is rediculous to run a 2.2x 60' also, power down low is not used at the track. by 30' i am in the upper rpms. i redline at 6k rpms and when i shift, it drops to 4500 (which is a healthy ways into the powerband). i have the car setup compromiseably for street/strip use, but also remember this is an everyday driver with over 104k miles on it.
#18 | |
14.79 @ 92.15
lookin at a 2.1x 60' as well (crosses fingers)
AB, like I was telling you before, get some 44K engine cleaner for your engine. I actually felt a difference after was done with it on all of the high milage cars ive done it to. They're only $10 a piece and i'd bet your car'd only need one, it would knock all of the carbon out of your engine and then the only thing you'd have to worry about it from being high miles is compression loss. Cheap hp man.
But what ever...
Threads Similar to: Drag radials
| New Drag Radials! | TripleBlackCobra | Drag | 35 | November 16th, 2007 02:39 PM |
| Drag Radials | MATT02GT | 99-04 | 46 | September 19th, 2007 11:44 PM |
| Drag Radials | RandoGT | 96-98 | 3 | August 25th, 2007 01:15 PM |
| Drag Radials | myeleanor | 2005 - 2010 | 32 | April 18th, 2007 07:21 PM |
| DRAG RADIALS, STILL NEED HELP!? | sweet99 | 99-04 | 7 | December 21st, 2006 02:31 AM |
