V6 EGR Ports
Old December 28th, 2008, 11:28 PM   #1
Dragonhunt is on a distinguished road
V6 EGR Ports
Can anyone tell me or show me where the EGR ports are on the engine? I need to unclog them.
Thanks
Old December 28th, 2008, 11:37 PM   #2
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
Searching pwns you lol
egr valve
Originally Posted by 06RedfireGT View Post
Hell, I'd suck his dick on TV for 52 cents lol
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old December 28th, 2008, 11:46 PM   #3
egr valve
Hey, Thanks, I was told there are small ports on the intake manifold that maybe clogged, thus forcing to much egr gases into my 1st spark plug.
Old December 29th, 2008, 08:49 AM   #4
2003 Mustang V6
a_kraker99 is on a distinguished road
check out the picture in the middle of this thread
EGR gas recirculation
I can see how it would be possible for one of those to get clogged but then you would just have less in 1 cylinder and slightly more in all the rest. Is your 1st spark plug fouling? Maybe that is the one that is clogged and you are running too rich on that cylinder.
Old December 29th, 2008, 04:16 PM   #5
I agree it seems odd that these can get clogged, so I am going to do these things: 1. Take off the intake runner like you have shown me and clean the holes out, put on a new ERG Valve 2. Do a compression Test if this is okay and there are no issues, then I will 3. Clean or replace the injectors
After that, I will be lost.
I do know that when I unplug the vacuum from the EGR, it does not seem to miss out underload like it did before... any ideas?
Old December 29th, 2008, 05:29 PM   #6
stephen has a spectacular aura aboutstephen has a spectacular aura about
The EGR valve is the part in the picture to the left of the radiator hose with a part number starting with XL7E.
Image of engine detail - Photobucket - Video and Image Hosting
Missing under load could be a dirty plug. However, if disconnecting the EGR vacuum line makes it go away it could be a clogged EGR port. I believe you would have to remove the intake manifolds to clean that out.
Old December 29th, 2008, 05:43 PM   #7
Safi's Avatar
00 v6 & 99 Cobra
You dont have to remove the intake manifolds to clean the EGR valve. Just take it off and clean it out
A common problem is for EGR valves to get coated in carbon and stick in one position. If you take off the EGR valve and tap the pintle against a table or something hard to break the carbon loose, then use carburetor cleaner (let soak for 1/2 hour or so) and clean it out, most of the time you'll fix it. If the vacuum diaphragm has failed, then there's nothing you can do to fix it.
Threads Similar to: V6 EGR Ports
Anybody know how to open ports on a Netgear router? 06RedfireGT The Clubhouse 50 April 13th, 2008 12:03 PM
Matching Ports usmcsawgunner 5.0 Mustangs 14 April 12th, 2008 01:26 PM
Ports? boyblue V6 Mustangs 2 February 12th, 2008 07:50 PM
plugging emissions ports Racinjason81 5.0 Mustangs 1 June 18th, 2007 07:59 PM
split ports and intakes. magicman55 V6 Mustangs 3 May 27th, 2007 06:14 PM
