dont no wat it is
Old December 28th, 2006, 05:11 PM   #1
Rolis is on a distinguished road
Send a message via MSN to Rolis Send a message via Yahoo to Rolis
dont no wat it is
ok im having probs wit my car itll start up sometimes and other times it won't. and when i finally do get it to start itll be running fine and then i park and try to turn it back on it wont other times itl start like shaking when im driving. i changed teh baterry and it still does the same.
Old December 28th, 2006, 05:13 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
have you checked your started that could be it.
NCMM #9
Old December 28th, 2006, 05:14 PM   #3
no i havent how do i check it
Old December 28th, 2006, 05:16 PM   #4
MM's Resident Ricer
2006 Scion tC
13.001@113
I'm not sure on that I just know thats one thing thats a problem a lot of times.
NCMM #9
Old December 28th, 2006, 05:17 PM   #5
alrite well wat else can be the prob
Old December 28th, 2006, 05:18 PM   #6
alrite well wat else can be the problem
Old December 28th, 2006, 05:19 PM   #7
MM's Resident Ricer
2006 Scion tC
13.001@113
umm not sure ignition wires maybe or your alternator.
NCMM #9
Old December 28th, 2006, 05:19 PM   #8
i dont think its the alternater cuz i have lil less than a year wit it
Old December 28th, 2006, 05:20 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
oh umm spark plugs might also be a possibility.
NCMM #9
Old December 28th, 2006, 05:21 PM   #10
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
check the teeth on your starter, check to see if your alternator is holding a charge, spark plugs may need changing. Since it does start I don't think it would be fuel related, but if your worried about that too. Change your fuel filter, and also get some fuel injector cleaner.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old December 28th, 2006, 05:21 PM   #11
well i try to look at it later cuz its snowing out rite now
Old December 28th, 2006, 05:23 PM   #12
Zoolander
iTrader: 5 reviews
Starters and alternators are tricky little buggers. They can be brand new, and not work. So don't count them out. If this happens in the cold then I would def check your alternator. Sounds like it's not taking enough of the amps since it's cold.
MM Cobra Club #18
Team Tini Racing
Old December 28th, 2006, 05:23 PM   #13
what do u mean by the teeth on the starter and how do i know if the spark plugs need to be changed
Old December 28th, 2006, 05:42 PM   #14
Zoolander
iTrader: 5 reviews
starters have teeth on them. Here, this should help.
Originally Posted by http://news.carjunky.com/how_stuff_works/how_car_starters_work_cs2356.shtml
Electric starter – this is the modern starter motor and it is a series wound direct current electric motor with a solenoid switch that is similar to a relay, mounted on it. When the low-current power from the starting battery is applied to the solenoid (this is usually through a key operated switch), it will push out a small pinion gear on the starter motor’s shaft and meshes it with the ring gear on the flywheel of the engine. The solenoid will also close high current contacts for the starter motor and it will start running. When the engine starts up, the key operated switch is opened and a spring in the solenoid assembly will pull the pinion gear away from the ring gear, and the starter motor will then stop. In modern starter motors there is a “bendix” – which is a gear and integral freewheel, or an overrunning clutch. This will enable the flywheel to automatically disengage the pinion gear from the flywheel when the engine starts.
MM Cobra Club #18
Team Tini Racing
Old December 28th, 2006, 05:43 PM   #15
Zoolander
iTrader: 5 reviews
Usually about once a year or so I will change my spark plugs.
MM Cobra Club #18
Team Tini Racing
Old December 28th, 2006, 05:55 PM   #16
umm i really did not get wat u wrote but ill read it over and try to understand it so wat spark plugs should i use or does it matter.
Old December 28th, 2006, 08:30 PM   #17
Tlord18 is on a distinguished road
A good test of an alternator is go in your car, start it up, and rev it past 4 or 5 grand. If the headlights dim or the battery lights pops up, then its time for a new one.I just replaced my alternator which was very easy and took about 10 minutes to do.BTW If my sig. is huge, i am trying to resize it but for some reason it wont. Sorry :wink
Old December 28th, 2006, 08:34 PM   #18
its all good il try out wat u said
Old December 28th, 2006, 09:38 PM   #19
Zoolander
iTrader: 5 reviews
Also check your amp guage on your cluster...if it starts to drop a lot your alternator is not keeping a charge. Your guage cluster will also lose light before your lights dim more and more. Well atleast mine will...probably a little more evident with my guages though.
MM Cobra Club #18
Team Tini Racing
Old December 28th, 2006, 10:53 PM   #20
Tree Fiddy Z
Breakout's Avatar
2006 Nissan 350Z
Breakout is a jewel in the roughBreakout is a jewel in the roughBreakout is a jewel in the rough
Send a message via AIM to Breakout
I would give the car a good tune up with good plugs/wires. Maybe a new fuel and air filter. That should do it if the car is actually trying to turn over. If you're turning the key and nothing happens...then it could be battery/alternator/starter.
Threads Similar to: dont no wat it is
Dont know scxc15 V6 Mustangs 14 April 2nd, 2007 01:18 PM
dont rag on me to much notsoslo5.0 5.0 Mustangs 7 March 6th, 2007 04:53 PM
Dont know what to do... scxc15 V6 Mustangs 23 February 2nd, 2007 06:41 PM
huh i dont get it noppe180 96-98 28 January 17th, 2007 06:49 PM
dont know what to do 9stang1 5.0 Mustangs 1 January 16th, 2007 08:54 PM
