2000 Mustang V6
need to run at track
![]() iTrader: 2 reviews
v6 tranny?
i have a 2000 v6, wat transmission do i have, oh im an auto
im looking to upgrade my tranny but keep it auto, do they have race transmissions that are auto? are any of these trans any good? Delk Performance |
#2 | |
you can do a Jmod if you haven't already.
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
4r70w, get a shift kit and stall before you upgrade the tranny like Stangcharger said.
Hip Hop Artist
Byebye V6~
Welcome Home New Pony :P
a built 4r70w is your best bet . then a b&m shift kit
![]() ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig http://www.myspace.com/moddedmustangz Modded Mustang's Song
doesnt even need to be a "built" 4r70w, like SC said, they can handled upwards of 400 hp stock.
the first time your car chirps into 2nd you will need new shorts.
2001 v6 premium
Yea the stock 4R70W is pretty nice for an AODE. Do the J-Mod and get a stall converter and you will be good for track use. Adjusting the shift points with a DiabloSport Predator is a good idea too...
2000 Mustang V6
i can chirp into second right now, i have a sniper tuner
now which is better....they j mod or the shift kit? |
#9 | |
I cant imagine my tranny shifting any harder under WOT |
2000 Mustang V6
so would it benefit me to get both the jmod and the shift kit? or would that be too much
a jmod is a shift kit.
A b&m kit and a jmod kit are both shift kits, they just do the same task in a different way. You cant have both I have a shift kit and a tuner to increase line pressure. Works great. |
2000 Mustang V6
oh didnt know that, thanks
ill probably get the jmod myself |
yea, you can do the jmod yourself, but there is a company that makes jmodded valve bodys that you swap in. then you have to send your stock valve body in. A b&m kit is just some springs and gaskets.
2000 Mustang V6
sounds a lot easier, did it make a big difference for you?
wat mods do you have anyway? running a 14.4 |
#15 | |
Yeah, it really did. It impresses alot of people (not being cocky at all) when you drive by a crowd and it chirps into gear. Plus, it makes your car feel completely different. check garage for mods, i should be 13s but my wheels weigh alot. |
beh anything but DELK
2001 v6 premium
Yea the B&M Valve Body Kit and the J-Mod are the same basically, but I would suggest doing the J-Mod and then getting either the DiabloSport Predator, SCT XCal, or Sniper Tuner to change your physical shift points and pressure.
With the tuner you can tell the pressure that it shifts and the point at which it shifts. The j-mod determines how quick it shifts (like a heel-toe shift versus a double clutch). If you don't think you need the tuner, this is another good mod. |
Zoolander
04 Cobra #2260/3768 1/820
a shift kit "bangs" into gear where as a stock it "slides" into gear which puts more of a strain on the transmission. So under normal driving conditions a shift kit actually prolongs the life of your transmission if installed correctly.
a shift kit, higher stall, and a tuner is a good combo when doing some transmission stuff. It will def put a smile on your face. But if your going to do that make sure you build your rear end up first. It still isn't cool doing the one wheel peel or only chirping a tire instead of tires |
word on the T-lock. and while doing that i reccomend 4.10 gears. with gears, j-mod, and tuner, your going to be very please with the outcome. and that tuner will gain some ponies as well.
MM's Resident Ricer
2006 Scion tC
13.001@113
if you want a stronger tranny get a lentech with an upgraded stall, the super street with a 2800 or 3000 stall is like a grand, or a shift kit, tuner, and ratchet shifter would be a good alternative
Threads Similar to: v6 tranny?
| tranny? | 87merkur | 5.0 Mustangs | 5 | August 13th, 2008 09:26 PM |
| Tranny shifts hard - tuner frys tranny/engine? | tangbang | V6 Mustangs | 4 | May 27th, 2008 01:09 PM |
| Tranny Gone? | Thejules | 5.0 Mustangs | 9 | December 5th, 2007 02:47 PM |
| T-56 Tranny in a GT? | Keegan_Vann | 99-04 | 39 | January 15th, 2007 09:57 PM |
| What tranny is this | Booger | 5.0 Mustangs | 4 | January 7th, 2007 02:05 PM |
