1996 ford mustang
building rearend is this all i need ?
just making sure this is all i need to build my rearend if its not let me no
Motive Performance Plus 4.10 Gears for 7.5in Rear Ford Racing 7.5" 28 Spline Traction - LOK Limited Slip Differential Motive Bearing Kit (7.5in) fluid and friction modifier oh and how much HP can this setup hold ? |
sounds good to me.
Not sure of the hp, i think its in the 350-400 area. Torres would know, hes pretty much pushing his to the limit. |
1996 ford mustang
well my car will be making about 50hps less then his in a couple of months so then i guess ill be ok
2002 Mustang V-6
15.8 @ 89 mph 2.4 60' siezed R-calipers
let me put it this way, the tlok is the same strenght as the stock open diff, which ive blow 2 up on my intake/exhaust auto vert.
i will be stepping up to a detroit true trac next time it happens
Have you thought about getting an 8.8 instead of doing a build up??
Threads Similar to: building rearend is this all i need ?
| 8.8 rearend. | gt_andy | Drag | 11 | May 16th, 2008 04:24 PM |
| what rearend should i use? | etony89 | 5.0 Mustangs | 26 | May 26th, 2007 07:59 PM |
| 9 in rearend? | solareclpse2000 | 5.0 Mustangs | 7 | January 9th, 2007 09:25 AM |
| Rearend | thewayshemoves | 99-04 | 6 | December 27th, 2006 11:31 AM |
