Rotor replacement?
LinkBack (1) Thread Tools
Old January 2nd, 2009, 03:14 PM   1 links from elsewhere to this Post. Click to view. #1
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
Rotor replacement?
About a week ago my brakes started making a metal scraping sound. When I looked at them the passenger side rotors are scraped pretty badly.
The rotors on the driver side are fine, but all the break pads are getting replaced for sure.
Should I replace the rotors or have them turned? Either way will I need to do the same thing on both sides or can I just do one side?
Old January 2nd, 2009, 08:23 PM   #2
1996 ford mustang
theyanks904 is on a distinguished road
i promise you have to replace both rotors and pads if you dont want to have problems with your brakes later down the line i dont care what anyone says thats they way you have to do the brakes
Old January 2nd, 2009, 09:56 PM   #3
Stang Tech's Avatar
2003 Mustang GT Vortech
Stang Tech is on a distinguished road
Send a message via AIM to Stang Tech
replace the rotor's unless you more problems
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Old January 2nd, 2009, 11:33 PM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
I'm assuming you just need the front brakes.
I would take the rotors to a machine shop and see if they can be machined or replace them with new and put in new pads. If the one worn rotor can't be machined but the other is good, you could replace the bad one with a new one and have both of them machined to the same thickness.
The easiest way to do the job is to loosen and remove the caliper bolts, and suspend the calipers out of the way, then unbolt the brackets. To reassemble it, put the rotors and brackets back in and install the pads, then compress the caliper pistons and reinstall them. Pump the brake pedal a few times to seat the pads against the rotors.
Old January 3rd, 2009, 07:49 PM   #5
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
well I just spent my Saturday replacing all 4 rotors and pads. Went pretty well for my first brake job. Even gave my wheels the good cleaning they've been needing.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/103726-rotor-replacement.html
Fique por dentro Rotor » Blog Archive » Rotor replacement? This thread Pingback January 19th, 2009 11:19 AM
Threads Similar to: Rotor replacement?
better cap/rotor chappys4life Classic Mustangs 3 October 28th, 2008 08:43 AM
rotor question bullitt ak 99-04 3 October 9th, 2008 02:34 PM
msd cap and rotor.. Chris951 5.0 Mustangs 19 September 28th, 2008 02:09 AM
Rotor question. Reggedon 99-04 9 September 24th, 2008 09:15 PM
Rotor Question? JAY'SRED02 2005 - 2010 13 January 24th, 2008 03:51 AM
