1999 Ford Mustang
Slow..more then likely
Help
all right boys need some help.
I start the car and the RPM's bounce and the whole car shakes. so I looked under the hood poked around and I couldnt find anything. So I thought maybe it was my spark plugs, so got some new sparks plugs (couldnt get 1 of them in becuase my exhaust manifold on the right side was just replaced not that long ago. Well when they replaced the manifold they have it to were I cant get my socket on the spark plug, Im taking the car back to them to fix that) so anyways...replaced the 5 other spark plugs, got in the car and went to get gas...ran fine. came home and had to go back to town, turned the car on and it rattled and did the same exact same thing! ![]() so any ideas as to what it could be??
![]() "One of the greatest challenges in life is knowing when to pick up your marbles and go home." |
MMs Ford Racing Nut Swinger
2007 MUSTANG GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Try adding a couple bottles of heat to the gas tank. Probably water in the gas.
1999 Ford Mustang
say what now...???? never heard of that before...but I just put a full tank of gas in...
i'm having a similar issue..
well on saturdays only mainly lol.... its pretty much when I drive, get out... go into a store or something.. go back to the car... get out at another store, leave.... so like the 3rd or 4th time in a short while... at that point when i try to turn my car on, it shakes and feels like its gonna die (rpms bounce sometimes too) I have tried a different MAF sensor.. i just got he oil changed so im gonna see if that did anything.. but many ppl said to check out my Throttle Position Sensor. Blondie.. by the way.. where in FL are you?
'91 Ford Escort LX - SOLD '81 Chevy Corvette - SOLD '94 Toyota Celica (Supra) - SOLD '97 Ford Mustang - R.I.P / SOLD '07 Ford Mustang V6 - "Dad's Ride" '08 Ford Mustang GT - \m/ Rocking \m/
muneris pro ego
clean out your air filter... i had a problem with the same symptoms, cleaned out my intake and car ran fine
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
could it possibly be something with the distributor cap? Maybe it's doing something to the plugs?
2003 V6 Mustang
14.2 @ 96
sounds like the EGR, take it off and clean it. I think its the EGR im thinking of, either that or the IAC. The thing that is on the back of your upper intake.
1999 Ford Mustang
My oil was just change and it also got a new air filter at the same time...so I dont know
Im going to take it to the shop this coming up week and see what they say just wanted to see what you guys thought.and Im about 30mins out of Gainesville. You?
1999 Ford Mustang
hmm okay I'll try that too
The Hammer
Millenium Falcon
r u throwing and codes?
1999 Ford Mustang
huh?
The Hammer
Millenium Falcon
check engine light
yeah check and see if your check engine light is on. If it is try to get to an autozone or something and have them pull the codes for you. it's free
1999 Ford Mustang
hmm okay...I'll do that to
2003 Mustang GT Vortech
clean out the IAC it's easy and take like 5 min or less. it controls the idle and is located on the bad side of the throttle body it has to bolt's and 1 connector. that should fix it if not try replaceing the othere spark plug's and wires and replace the fuel filter if you haven't done so yet.
Ford Certified Tech Land Rover Certified Tech Ase Certified Tech Honda/ Acura Certified Tech AllData Automotive Information Specialist 03 Mustang GT Vortech V3 Intercooled 407/415 to the wheels BOOOOSSSTTTTTT
1999 Ford Mustang
SWEET! thanks and I'll try that tom
Could be a bad sensor
The soul stealing Ginger
Did it do this before you put that full tank of gas in?
1999 Ford Mustang
