HELP!! how do i remove the crank shaft pulley??
Old December 29th, 2006, 04:16 PM   #1
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
aight im trying to get this fuckin pulley off but it just keeps spinning any suggestions??
Old December 29th, 2006, 04:19 PM   #2
Zoolander
04 Cobra #2260/3768 1/820
iTrader: 5 reviews
I loosened the bolts with the belt still on so it had some tension on it. If that doesn't work get a buddy to hold it as tight as possiblt. If you do the belt idea, just loosen the bolts don't take them off with the belt still on.
MM Cobra Club #18
Team Tini Racing
I don't know jack shit...
Old December 29th, 2006, 04:21 PM   #3
Onemanzu's Avatar
... shit so i have to put the water pump pulley back on then the belt... did you have to fuck with the vibration damper on your swap?
Old December 29th, 2006, 04:23 PM   #4
Zoolander
iTrader: 5 reviews
You don't have to change the waterpump pulley out. Only the crankshaft pulley requires the shorter belt. Nope...I just took the bolts off, took the pulley off, and put the new one on. I also put some threadlocker by loc tite on there just for some added insurance. I used the blue one, not the red one.
MM Cobra Club #18
Team Tini Racing
Old December 29th, 2006, 04:33 PM   #5
Onemanzu's Avatar
yea no its still spinnin... any other ideas??
i have to get to the front of the block thats why i have the water pump half out...
Old December 29th, 2006, 04:43 PM   #6
Onemanzu's Avatar
could i put it in gear chalk the back wheels and use the car's transmission to stop it from rotating?? or would i be putting to much torque on the drivetrain?
Old December 29th, 2006, 04:58 PM   #7
Zoolander
iTrader: 5 reviews
It will still spin that way. Umm Try using a buddy to hold it still or use another socket wrench to hold on of the bolts in place whil you loosen another. Just becareful with the second one.
MM Cobra Club #18
Team Tini Racing
Old December 30th, 2006, 01:59 AM   #8
Onemanzu's Avatar
aight ill try the buddy thing... if only i had friends... kk cool thanks dude
Old December 30th, 2006, 02:48 AM   #9
Zoolander
iTrader: 5 reviews
no prob
MM Cobra Club #18
Team Tini Racing
Old December 30th, 2006, 10:42 AM   #10
stang94 is on a distinguished road
Get superman to hold it and get a air gun and keep shooting... lol.. no what cricket said should work..
and I think you been here long enough to know no to post one topic twice.
http://www.moddedmustangs.com/forums...y-vt11271.html
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old December 30th, 2006, 02:27 PM   #11
themav46 is on a distinguished road
Send a message via AIM to themav46
i had the same problem and eventually took it with me to get my oil changed and they did it for me. and impact wrench helps.
1996 V6 Mustang
Old December 30th, 2006, 02:45 PM   #12
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
take a floor jack and position it under the crank pulley. lift it enough so that it puts some tension on the crank pulley but not enough to lift the motor. then put a socket on it and give it hell. worked for me
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old December 30th, 2006, 02:47 PM   #13
Resident Bubblehead
00vabchgt's Avatar
btw youl'll need a harmonic balancer puller to remove the crank pulley once the nut comes off. there should be a washer that sits under the nut, make sure that comes out before you try to pull off the crank pulley or else it won't move. good luck
Military Crew
MM1 (SS)
US Navy Veteran
Threads Similar to: HELP!! how do i remove the crank shaft pulley??
98 crank pulley question 98mustang V6 Mustangs 3 August 16th, 2007 03:56 PM
crank pulley mikedoogen Modular Mustangs 3 June 20th, 2007 02:22 AM
crank pulley help mikedoogen 2005 - 2010 3 June 19th, 2007 02:17 PM
they remove the drive shaft right? YNOT 5.0 Mustangs 8 May 13th, 2007 02:55 PM
Crank Pulley diameter 97TunedMustang V6 Mustangs 2 February 7th, 2006 08:26 PM
