LinkBack (1) | Thread Tools |
#1
trouble codes
Hey can we get this stickied in our section too?
P0102- Mass Air Flow circuit Low Input. P0103- Mass Air Flow circuit High Input. P0106- EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range. P0107- EGR/BARO Signal circuit is Less Than Self-Test minimum. P0108- EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range. P0112- Intake Air Temperature circuit Low Input. P0121- In-Range Operating Throttle Position Sensor circuit failure. P0122- Throttle Position Sensor circuit Low Input. P0123- Throttle Position Sensor circuit High Input. P0125- Insufficient Coolant Temperature to enter Closed Loop. P0126- Insufficient Coolant Temperature for Stable Operation. P0113- Intake Air Temperature circuit High Input. P0117- Engine Coolant Temperature circuit Low Input. P0118- Engine Coolant Temperature circuit High Input. P0121- In-Range Operating Throttle Position Sensor circuit failure. P0122- Throttle Position Sensor circuit Low Input. P0123- Throttle Position Sensor circuit High Input. P0125- Insufficient Coolant Temperature to enter Closed Loop. P0126- Insufficient Coolant Temperature for Stable Operation. P0131- Upstream Heated Oxygen Sensor circuit out of range - Bank No. 1. P0132- Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1. P0133- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1. P0135- Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1. P0136- Downstream Heated Oxygen Sensor circuit fault - Bank No. 1. P0138- Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1. P0140- Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1. P0141- Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1. P0151- Upstream Heated Oxygen Sensor circuit out of range - Bank No. 2. P0152- Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2. P0153- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2. P0155- Upstream Heated Oxygen Sensor circuit fault - Bank No. 2. P0156- Downstream Heated Oxygen Sensor circuit fault - Bank No. 2. P0158- Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2. P0160- Downstream Heated Oxygen Sensor circuit fault - Bank No. 2. P0161- Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2. P0171- System Too Lean - Bank No. 1. P0172- System Too Rich - Bank No. 1. P0174- System Too Lean - Bank No. 2. P0175- System Too Rich - Bank No. 2. P0176- Flexible Fuel Sensor. P0180- Engine Fuel Temperature Sensor circuit - Electrical fault. P0181- Engine Fuel Temperature Sensor circuit - Electrical fault. P0182- Engine Fuel Temperature Sensor circuit - Electrical fault. P0183- Engine Fuel Temperature Sensor circuit - Electrical fault. P0187- Engine Fuel Temperature Sensor circuit. P0188- Engine Fuel Temperature Sensor circuit. P0190- FRP Sensor Signal Low. P0191- Engine Fuel Temperature Sensor circuit. P0192- Engine Fuel Temperature Sensor circuit . P0193- Engine Fuel Temperature Sensor circuit. P0222- Throttle Position Sensor B circuit Input Low. P0223- Throttle Position Sensor B circuit Input High. P0230- Fuel Pump Primary circuit fault. P0231- Fuel Pump Secondary circuit Low. P0232- Fuel Pump Secondary circuit High. P0300- Random Misfire Detected. P0301- Misfire Detected - Cylinders 1-10. P0302- Misfire Detected - Cylinders 1-10. P0303- Misfire Detected - Cylinders 1-10. P0304- Misfire Detected - Cylinders 1-10. P0305- Misfire Detected - Cylinders 1-10. P0306- Misfire Detected - Cylinders 1-10. P0307- Misfire Detected - Cylinders 1-10. P0308- Misfire Detected - Cylinders 1-10. P0309- Misfire Detected - Cylinders 1-10. P0310- Misfire Detected - Cylinders 1-10. P0320- Ignition Engine Speed (PIP) Input circuit fault. P0325- A Spark Knock Occurred - Sensor Circuitry did not respond. P0326- Spark Knock has not been sensed. P0330- A Spark Knock occurred - Sensor Circuitry did not respond. P0331- Spark Knock has not been sensed. P0340- Camshaft Position Sensor circuit fault. P0350- Ignition Coil Primary circuit fault. P0351- Ignition Coil A Primary circuit fault. P0352- Ignition Coil B Primary circuit fault. P0353- Ignition Coil C Primary circuit fault. P0354- Ignition Coil D Primary circuit fault. P0355- Ignition Coil Primary circuit malfunction. P0356- Ignition Coil Primary circuit malfunction. P0357- Ignition Coil Primary circuit malfunction. P0358- Ignition Coil Primary circuit malfunction. P0359- Integrated Ignition On Plug failure. P0360- Integrated Ignition On Plug failure. P0385- Misfire Detection Sensor circuit failure. P0400- EGR Flow Faulty. P0401- Insufficient EGR Flow. P0402- EGR Flow Excessive at Idle. P0411- Secondary Air Injection System Flow Improper. P0412- Secondary Air Injection System Control Valve Faulty. P0413- Secondary Air Injection Solenoid did not change when activated. P0414- Secondary Air Injection Solenoid did not change when activated. P0416- Secondary Air Injection Solenoid did not change when activated. P0417- Secondary Air Injection Solenoid did not change when activated. P0420- Catalyst System Efficiency below Limit - Bank No 1. P0421- Catalyst System Efficiency below Limit - Bank No 1. P0430- Catalyst System Efficiency below Limit - Bank No 2. P0431- Catalyst System Efficiency below Limit - Bank No 2. P0440- Evaporative Emission Purge Control Solenoid Damaged. P0442- Leak in Evaporative System Detected. P0443- EVAP Canister Purge Control Solenoid or Valve Faulty. P0446- Evaporative Emission Control System Vent Control malfunction. P0452- Fuel Tank Pressure Signal circuit Input below minimum. P0453- Fuel Tank Pressure Signal circuit Input above maximum. P0455- Leak or Blockage Detected in Evaporative Emission Control System. P0460- Fuel Level Input circuit malfunction. P0500- Vehicle Speed Sensor fault. P0501- Vehicle Speed Sensor fault. P0503- Poor Vehicle Speed Sensor Performance. P0505- Idle Air Control Valve System fault. P0552- Power Steering Pressure Sensor Shorted to Power. P0553- Power Steering Pressure Sensor Shorted to Power. P0602- Replace PCM. P0603- PCM has Experienced Power Interrupt. P0605- PCM Read Only Memory Error. P0703- Brake On/Off Switch Input fault. P0704- Clutch Pedal Position Switch Input circuit fault. P0705- Transmission Range Sensor out of Self-Test Range or Shorted to Ground. P0707- Transmission Range Sensor circuit Low Input. P0708- Transmission Range Sensor circuit High Input. P0712- Transmission Fluid Temperature Sensor circuit Input Low. P0713- Transmission Fluid Temperature Sensor circuit Input High. P0715- Turbine Shaft Speed Sensor circuit fault. P0720- Output Shaft Speed Sensor circuit. P0721- Output Shaft Speed Sensor circuit. P0731- Improper Ratio for First Gear. P0732- Improper Ratio for Second Gear. P0733- Improper Ratio for Third Gear. P0734- Improper Ratio for Fourth Gear. P0735- Transmission problems. P0736- Improper Ratio for Reverse Gear. P0741- TCC System Improper Mechanical Performance. P0743- Torque Converter Clutch System Electrical failure. P0746- Electronic Pressure Control Solenoid Performance. P0750- Shift Solenoid No. 1 circuit. P0751- Shift Solenoid No. 1 Performance. P0755- Shift Solenoid No. 2 circuit. P0756- Shift Solenoid No. 2 Performance. P0760- Shift Solenoid No. 3 circuit. P0761- Shift Solenoid No. 3 Performance. 70765- Transmission system problems. P0781- 1 to 2 Shift Error. P0782- 2 to 3 Shift Error. P0783- 3 to 4 Shift Error. P0784- 4 to 5 Shift Error. P1000- OBD-II Monitor Testing Incomplete. P1001- KOER Test Cannot Be Completed. P1039- Vehicle Speed Signal Missing or Improper. P1051- Brake Switch Signal Missing or Improper. P1100- Mass Air Flow Sensor Intermittent. P1101- Mass Air Flow Sensor out of Self-Test Range. P1112- Intake Air Temperature Sensor Intermittent. P1116- Engine Coolant Temperature Sensor is out of Self-Test Range. P1117- Engine Coolant Temperature Sensor Intermittent. P1120- Throttle Position Sensor out of range. P1121- Throttle Position Sensor Inconsistent with Mass Air Flow Sensor. P1124- Throttle Position Sensor out of Self-Test Range. P1125- Throttle Position Sensor Intermittent. P1127- Heated Oxygen Sensor Heater not on During KOER Test. P1128- Heated Oxygen Sensor Signals reversed. P1129- Heated Oxygen Sensor Signals reversed. P1130- Lack of Upstream Heated Oxygen Sensor/Adaptive Fuel Limit/Bank 1. P1131- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 1. P1132- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 1. P1135- Ignition Switch Signal Missing or Improper. P1137- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 1. P1138- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 1. P1150- Lack of Upstream Heated Oxygen Sensor/Adaptive Fuel Limit/Bank 2. P1151- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 2. P1152- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 2. P1157- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 2. P1158- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 2. P1220- Series Throttle Control fault. P1224- Throttle Position Sensor B out of Self-Test Range. P1230- Open Power to Fuel Pump circuit. P1231- High Speed Fuel Pump Relay activated. P1232- Low Speed Fuel Pump Primary circuit failure. P1233- Fuel Pump Driver Module off-line. P1234- Fuel Pump Driver Module off-line. P1235- Fuel Pump Control out of range. P1236- Fuel Pump Control out of range. P1237- Fuel Pump Secondary circuit fault. P1238- Fuel Pump Secondary circuit fault. P1250- Lack of Power to FPRC Solenoid. P1260- Theft Detected - Engine Disabled. P1270- Engine RPM or Vehicle Speed Limiter Reached. P1288- Cylinder Head Temperature Sensor out of Self-Test Range. P1289- Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range. P1290- Cylinder Head Temperature Sensor Signal Less Than Self-Test Range. P1299- Cylinder Head Temperature Sensor Detected Engine Overheating Condition. P1309- Misfire Detection Monitor not enabled. P1351- Ignition Diagnostic Monitor circuit Input fault. P1352- Ignition Coil A - Primary circuit fault. P1353- Ignition Coil B - Primary circuit fault. P1354- Ignition Coil C - Primary circuit fault. P1355- Ignition Coil D - Primary circuit fault. P1356- Loss of Ignition Diagnostic Module Input to PCM. P1358- Ignition Diagnostic Monitor Signal out of Self-Test Range. P1359- Spark Output circuit fault. P1364- Ignition Coil Primary circuit fault. P1380- VCT Solenoid Valve circuit Short or Open. P1381- Cam Timing Advance is excessive. P1383- Cam Timing Advance is excessive. P1390- Octane Adjust out of Self-Test Range. P1400- Differential Pressure Feedback Electronic Sensor circuit Low Voltage. P1401- Differential Pressure Feedback Electronic Sensor circuit High Voltage. P1403- Differential Pressure Feedback Electronic Sensor Hoses Reversed. P1405- Differential Pressure Feedback Electronic Sensor circuit Upstream Hose. P1406- Differential Pressure Feedback Electronic Sensor circuit Downstream Hose. P1407- EGR No Flow Detected. P1408- EGR Flow out of Self-Test Range. P1409- EGR Vacuum Regulator circuit malfunction. P1410- EGR Barometric Pressure Sensor VREF Voltage. P1409- Electronic Vacuum Regulator Control circuit fault. P1411- Secondary Air is not being diverted. P1413- Secondary Air Injection System Monitor circuit Low Voltage. P1414- Secondary Air Injection System Monitor circuit High Voltage. P1442- Secondary Air Injection System Monitor circuit High Voltage. P1443- Evaporative Emission Control System/Vacuum System/Purge Control Solenoid or Purge Control Valve fault. P1444- Purge Flow Sensor circuit Input Low. P1445- Purge Flow Sensor circuit Input High. P1450- Inability of Evaporative Emission Control System to Bleed Fuel Tank. P1451- Lack of Response From Passive Anti-Theft System Module - Engine Disabled. P1452- Inability of Evaporative Emission Control System to Bleed Fuel Tank. P1455- Substantial Leak or Blockage in Evaporative Emission Control System. P1460- Wide Open Throttle Air Conditioning Cutoff circuit malfunction. P1461- Air Conditioning Pressure Sensor circuit Low Input. P1462- Air Conditioning Pressure Sensor circuit high Input. P1463- Air Conditioning Pressure Sensor Insufficient Pressure change. P1464- ACCS to PCM High During Self-Test. P1469- Low Air Conditioning Cycling Period. P1473- Fan Secondary High with Fans Off. P1474- Low Fan Control Primary circuit. P1479- High Fan Control Primary circuit. P1480- Fan Secondary Low with Low Fans On. P1481- Fan Secondary Low with High Fans On. P1483- Power to Cooling Fan Exceeded Normal Draw. P1484- Variable Load Control Module Pin 1 Open. P1500- Vehicle Speed Sensor Intermittent. P1501- Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure. P1502- Invalid or Missing Vehicle Speed Message or Brake Data. P1504- Intake Air Control circuit malfunction. P1505- Idle Air Control System at Adaptive Clip. P1506- Idle Air Control Over Speed Error. P1507- Idle Air Control Under Speed Error. P1512- Intake Manifold Runner Control Stuck Closed. P1513- Intake Manifold Runner Control Stuck Closed. P1516- Intake Manifold Runner Control Input Error. P1517- Intake Manifold Runner Control Input Error. P1518- Intake Manifold Runner Control fault - Stuck Open. P1519- Intake Manifold Runner Control Stuck Open. P1520- Intake Manifold Runner Control circuit fault. P1519- Intake Manifold Runner Control fault - Stuck Closed. P1520- Intake Manifold Runner Control fault. P1530- Open or Short to A/C Compressor Clutch circuit. P1537- Intake Manifold Runner Control Stuck Open. P1538- Intake Manifold Runner Control Stuck Open. P1539- Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw. P1549- Intake Manifold Temperature Valve Vacuum Actuator Connection. P1550- Power Steering Pressure Sensor out of Self-Test Range. P1605- PCM Keep Alive Memory Test Error. P1625- Voltage to Vehicle Load Control Module Fan circuit not detected. P1626- Voltage to Vehicle Load Control Module circuit not detected. P1650- Power Steering Pressure Switch out of Self-Test Range. P1651- Power Steering Pressure Switch Input fault. P1700- Transmission system problems. P1701- Reverse Engagement Error. P1702- Transmission system problems. P1703- Brake On/Off Switch out of Self-Test Range. P1704- Transmission system problems. P1705- Manual Lever Position Sensor out of Self-Test Range. P1709- Park or Neutral Position Switch out of Self-Test Range. P1710- Transmission system problems. P1711- Transmission Fluid Temperature Sensor out of Self-Test Range. P1713- Thru P1728 Transmission system problems. P1729- 4x4 Low Switch Error. P1740- Transmission system problems. P1741- Torque Converter Clutch Control Error. P1742- Torque Converter Clutch Solenoid Faulty. P1743- Torque Converter Clutch Solenoid Faulty. P1744- Torque Converter Clutch System Stuck in Off Position. P1745- Transmission system problems. P1746- Electronic Pressure Control Solenoid - Open circuit. P1747- Electronic Pressure Control Solenoid - Short circuit. P1749- Electronic Pressure Control Solenoid Failed Low. P1751- Shift Solenoid No. 1 Performance. P1754- Coast Clutch Solenoid circuit malfunction. P1756- Shift Solenoid No. 2 Performance. P1760- Transmission system problems. P1761- Shift Solenoid No. 3 Performance. P1762- Transmission system problems. P1767- Transmission system problems. P1780- Transmission Control Switch circuit is out of Self-Test Range. P1781- 4x4 Low Switch is out of Self-Test Range. P1783- Transmission Over-Temperature Condition. P1784- Transmission system problems. P1785- Transmission system problems. P1786- Transmission system problems. P1787- Transmission system problems. P1788- Transmission system problems. P1789- Transmission system problems. P1900- Transmission system problems. |
#2 | |
muneris pro ego
Re: trouble codes
Definitely needs to be a sticky
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
MM's Resident Ricer
2006 Scion tC
13.001@113
I agree
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/10496-trouble-codes.html
| p1289 cylinder head temperature sensor signal greater than self test range | Temperature Sensor | This thread | Refback | May 19th, 2011 10:27 PM | |
Threads Similar to: trouble codes
| Trouble Codes | GTsetGO | Modular Mustangs | 15 | December 4th, 2007 04:13 PM |
| trouble codes...HELP!!! | sleezy | 96-98 | 6 | July 10th, 2007 11:06 PM |
| SCT Trouble Codes! What to do? | wormster00 | 2005 - 2010 | 10 | July 6th, 2007 04:14 PM |
| Trouble codes | bigbadtalontsi | 5.0 Mustangs | 3 | March 30th, 2007 01:26 AM |
| trouble codes.... | stang fanatic | General Tech | 0 | July 7th, 2006 12:36 AM |
