Discussing i got a whining noise in the engine in the V6 Mustangs Forum. ok heres my little story...i have a 2003 v6 5 speed mustang that has ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 mustang v6
ok heres my little story...i have a 2003 v6 5 speed mustang that has 43000 miles on it. i got into a wreck about a month and a half ago and the hood, bumper, headlight mount, headlights, radiator and the power steering pulley. there has been a high pitched whining in my engine when i accelerate and when i push in the clutch and let the rpms drop the engine whines down too. i was thinking the pulley is bad or maybe the whole pump ive been searching everywhere for a solution. but all i seem to come up with is idler pulley, power steering pulley(maybe) and transmission. so i got the tranny checked and had new bearings put in, as well as blocker rings but that 1200 bucks didnt seem to help.
so can anyone help me with a similar experience or might have a clue.
2004 Mustang V6
14.4@ 96
take it back to where you got it fixed at and see if they can spot it. Obviously they didnt fix it right.
But, it could be anything, and its super hard to tell through the internet. Check and make sure nothing is rubbing. Or, put someone in the car and give it gas while you are looking in the engine compartment. See if you can pinpoint the noise that way. |
2003 mustang v6
i did that and i figured that since the pulley was replaced that it could be a bad pulley i took it back to them and they said they werent sure what it could be. they said maybe the pulley was bad. the pulley does have a little wobble so maybe the shaft of the pump is bent or maybe just the pulley is bad or the bearing in the pulley
2004 Mustang V6
14.4@ 96
start with whats cheap, and work up from there.
2003 mustang v6
sounds good to me
You could remove the serpentine belt and run the engine briefly to see if the noise goes away. If it does then it's some belt driven part, possibly the PS pump.
The PS pump seems likely since the pulley got bent. |
2003 mustang v6
thats really a great idea thank you
2000 Mustang v6
could be the throwout bearing in the clutch. Or at least that's what it was when my car did it.
Threads Similar to: i got a whining noise in the engine
| Help! 1997 GT whining noise at startup. | Blown 97 GT | 96-98 | 16 | January 8th, 2009 11:42 PM |
| 65 Engine Noise - Whining | Rolfey | Classic Mustangs | 1 | May 10th, 2008 09:01 AM |
| Whining Noise | scxc15 | V6 Mustangs | 12 | April 28th, 2008 10:43 AM |
| whining noise... | El_Cangri | V6 Mustangs | 63 | May 27th, 2007 11:56 AM |
| Need Answer (Whining Noise) | Kope | V6 Mustangs | 8 | December 6th, 2006 08:45 PM |
