shocks and struts
Old January 17th, 2006, 09:41 AM   #1
zhunter is on a distinguished road
Send a message via MSN to zhunter
shocks and struts
i recently damaged the rear end of my mustang. i backed out of a driveway and went down a hill too steep, and subsequently bent the exhaust pipe and damaged the shock i think, the sounds that it makes when you go over slight bumps is terrible, im hoping that someone can tell me what this could possibly be so i can save for the repairs.
Old January 17th, 2006, 10:05 AM   #2
mdvaldosta's Avatar
11.47@120.58
Replacement shocks are very cheap, like $30 for a set. But, I'm afraid without actually seeing the damage it'd be tough to make recommendations. You could have damaged alot of stuff, but fortunately everything is fairly inexpensive back there.
Old January 17th, 2006, 11:57 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
could also be the exhaust rubbing the control arm, just gotta look up under there and see what it is touching, bounce the rear of the vehicle or have a friend do it while you are under there. more than likely it is just bent exhaust tubing and maybe the exhaust hanger?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old January 17th, 2006, 12:00 PM   #4
if it is just exhaust you have a few options, spring for oem replacement/takeoffs, aftermarket cat back, have your stock y pipe modified to fit gt takeoff or catback, or just cut it off after the muffler?
Old January 17th, 2006, 05:12 PM   #5
I agree with 99
88 Mustang Coupe
www.rickscarcare.net
Threads Similar to: shocks and struts
KYB shocks and Struts ridebmxfbm 5.0 Mustangs 2 August 19th, 2007 02:34 PM
shocks and struts? MisterFast3 V6 Mustangs 2 July 31st, 2007 08:01 AM
Shocks and Struts MustangMatt96GT 96-98 6 February 14th, 2007 01:18 AM
Shocks/Struts DCstangGT 99-04 5 November 2nd, 2006 06:34 PM
Shocks / Struts hmotes General Tech 6 October 7th, 2006 12:41 AM
