Painting your interior inserts
Ive looked for the easy way out by trying to find ones pre painted. At this point im gonna try the high road and paint my inserts myself. Does anyone know what kinda paint do you use. Wats the prep work. And how do you get them out.
Onemanzu wrote: AB is like santa clause.... you just have to believe |
muneris pro ego
personally i used PPG primer and Du Pont paint.. thats high dollar car paint. if you want to go the cheap and easy route you can pick up spray cans at any store and do it yourself... you gotta remember to thoroughly clean the surface you are painting and scuff it really well so the primer will stick.. plastic adhesive will help as well.
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
Do you know how to pop them out like my door inserts and the one around my shifter and radio
1999 Ford Mustang V6
14.79 @ 92.15
use a small flathead to remove the light knob along its side slit. there are two small torx bits under the top of the guage display trim and the radio center trim. after removing this, everything just "pops" out with pressure from a flathead. the shifter trim just pops out with your hands.
Another tip is to use a real fine grit sand paper to rough up the surface a lil, not to the point that its visible just so you give the paint something to cling to. Afterwards make sure the pieces are clean. Also while painting the parts take ur time and use thin coats, if you do this itll come out lookin' great.
Thanks guys im gonna post pics of my car so everyone can help to decide wat color to paint them
again, make sure to clean the every piece really really good. you don't want any thing left on it or the paint will not lay right. i made that mistake and it turned out really bad. it was a mess and i ended up screwing it up. let us know how it works out
awesome article...I would make sure I painted the gauge surround too though, that will really make it stand out
#10 | ||
Duplicolor paint all the way.
¡ʇsnq ɹo uʍop ǝpısdn
here is a few pictures that might help you get some idea of how to get their and back
http://www.moddedmustangs.com/door-speaker-install.html
Thanks guys i should have that done and my halos done in a couple weeks then i will post pics
... ill race you... you do those two things and ill do my gasket... i bet youll win
My car isnt timed right i just got a new engine and it's not acting right
no not with cars... with mechanical know how to see who can finish their project's first
muahhaahaa.. i know all about it...........
if you do it yourself.. use "krylon fuzion" from walmart is a new paint made just for plastics NO PRIMING REQUIRED... so if you use primer you'll get a invincable coat and it wont scratch if you give it a couple of coats of clear when your done...
![]() If recycled beercans, duct tape and superglue wont fix it .. your prolly not driving a honda |
so prime it use the krylon stuff and clear coat thanks
haha right on i'm gona go look for that stuff now i feel like a new colour in my interior haha
I think I might actually reconsider doing this.. Now I kind of want to, but Im not sure....
Threads Similar to: Painting your interior inserts
| Painting interior | Tr1gger | 5.0 Mustangs | 16 | February 26th, 2008 08:59 PM |
| painting interior pieces? | tjames | V6 Mustangs | 12 | August 14th, 2007 10:00 PM |
| painting interior pieces | tjames | Visual | 2 | August 14th, 2007 06:16 PM |
| Interior Painting | stanged out | Visual | 9 | August 6th, 2007 10:45 PM |
| Painting my interior!! | itschristorres8 | V6 Mustangs | 82 | February 7th, 2007 01:41 PM |
