A rim question
Old February 2nd, 2009, 03:17 PM   #1
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
boblongtv is on a distinguished road
Send a message via AIM to boblongtv
A rim question
Will 18x9 rims fit on my 99 stang, without rubbing when you turn it? And how bad will that mess up my speedometer?
Old February 2nd, 2009, 03:26 PM   #2
2004 Mustang V6
04DSGV6 is on a distinguished road
It will fit as long as you don't get too high a profile tire and it really shouldn't make your speedo too inaccurate either. Plenty of people run this size without any issues.
Originally Posted by 06RedfireGT View Post
The idea of smashing your face on it in an accident isn't so sexy.
Old February 2nd, 2009, 03:32 PM   #3
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
Thats wat I figured because there saleen rims
Old February 2nd, 2009, 04:46 PM   #4
00BlueMustang's Avatar
2000 Mustang
00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough
You should be fine, I have seen some guys run 20's on the new edges, even though they were ugly they were fine and no rubbing
Old February 2nd, 2009, 05:48 PM   #5
I Hate Convertibles...
2000 GT Vert
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
i have 18x9s on my car with a 275-35-18 tire the tires rub a little bit in the front on the sway bar when i turn all the way. its not a big problem.... you wont even notice or damage anything. the smallest tire i would run on an 18x9 rim is a 265. i dont know if that tire size will rub or not tho.
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
Old February 2nd, 2009, 06:05 PM   #6
2000 GT Vert
oh and if you run a 265-35-18 tire your speedo will be off a little bit. when your speedo says 60 your going 59mph lol. with 275-35-18 tires your speedo should be right on.
mods/pics
Old February 2nd, 2009, 08:14 PM   #7
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
The rims say they come with a 235-40-18 size tire?
Old February 2nd, 2009, 08:33 PM   #8
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
It will only rub if you lower your car. When I turned the wheel all the way to the side, it would rub with FRPP C Springs and even more with Eibach Sportlines - and I have 17" wheels (275/40/17).
The math:
    1. 275/40/17:
  • Total Wheel/Tire Diameter = Total Sidewall Height + Wheel Diameter
  • Total Sidewall Height = 275mm*40%*2 = 220mm = 8.668"
  • Wheel Diameter = 17"
  • Total Wheel/Tire Diameter = 17" + 8.668" = 25.668"
    1. 245/40/18:
  • Total Sidewall Height = 245mm*40%*2 = 196mm = 7.7224"
  • Wheel Diameter = 18"
  • Total Wheel/Tire Diameter = 17" + 7.7224" = 25.7224"
So the overall diameter of the 18" wheel/tire package is only going to be (25.7224-25.668) 0.0544" and is negligible. Also, this is a narrower tire on the 18" wheel as opposed to the 17" wheel. You will rub the same amount between the two at equal ride heights.
ModdedAutos
1999 Mustang V6
Old February 2nd, 2009, 08:34 PM   #9
14.79 @ 92.15
That will be even narrower than my example in the previous post. You will rub less in this case.
p.s. Your overall Wheel/Tire Diameter will be smaller so your speedometer will be slightly affected; you will rub less in turning though. The difference will be very small if not negligible.
ModdedAutos
1999 Mustang V6
Old February 2nd, 2009, 08:44 PM   #10
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
So do you think I should lower my car?
Old February 2nd, 2009, 08:49 PM   #11
14.79 @ 92.15
Lowering your car is all in your preference and what you want in your car. I could not stand the 4x4 stance the Mustang has from the factory, so I dropped it with FRPP C springs (1.25") but it wasn't low enough. I then went with Eibach Sportlines (2.2" drop) and MM C/C plates. I prefer the lowered look, but it really is owner preference and your goals with your car will determine your decision.
I don't rub in normal daily driving. I only rub when I turn the wheel all the way to one side or the other.
ModdedAutos
1999 Mustang V6
Old February 2nd, 2009, 08:56 PM   #12
boblongtv's Avatar
1999 V-6, 1998 gt
Hey she looks fast
I no its my preference I was just wonderin wat you thought. Thanks
Old February 3rd, 2009, 10:28 AM   #13
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
+1 across the board with AB99... however on the case of tire width 265 the smallest?!? crazy why would want such wide tires on the front? I run 245's and I almost say too wide, 235's should be fine, as AB said that would equal less rubbing. I have Eibach prokit springs and tokico struts which lowers it around 1.5" and on full turn there is some rubbing, also on hard braking especially with passengers in the car. I say get rid of the 4x4 look though!
Old February 3rd, 2009, 10:34 AM   #14
goren813's Avatar
'00 3.8L & '05 4.6L
...also on the case of the speedo being off, I run 18x9/10 and 245-40 / 275-35 and the speedo is off a few MPH, no huge deal but if you're looking for a tune somewhere down the road I'm pretty sure some custom tunes can put your rim/tire size in the equation.
Old February 3rd, 2009, 10:37 AM   #15
14.79 @ 92.15
Right on. I have the SCT XCal II, and it has parameters for different size tires to correct the speedometer.
ModdedAutos
1999 Mustang V6
Old February 3rd, 2009, 10:41 AM   #16
04mustang232's Avatar
2004 Mustang V6
14.4@ 96
04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice04mustang232 is just really nice
Send a message via AIM to 04mustang232
unless you are running 35'' mud boggers...you'll be ok.
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
Old February 3rd, 2009, 11:04 AM   #17
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
can you tune different front and rear's?
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old February 3rd, 2009, 12:32 PM   #18
14.79 @ 92.15
Not with the XCal II.
ModdedAutos
1999 Mustang V6
Old February 3rd, 2009, 01:18 PM   #19
Hip Hop Artist
Youngin's Avatar
Byebye V6~
xcal 3?
Old February 3rd, 2009, 02:23 PM   #20
2000 GT Vert
im sayin on an 18x9 rim the smallest i would run is a 265. i dont like the idea of running such a small tire on a bigger rim. if you run a smaller tire on a wider rim the side wall will be at an angle do to the tire not being as wide as the rim and it will look really wierd.
your speedo wont be off by a few mph runing a 275-35 or a 245-40, it will be off less the 1mph so you dont have anything to worry about but yeah +1 on a tuner. you can change your speedo according to tire size.
mods/pics
Threads Similar to: A rim question
Rim question adrenaline=lifeline 99-04 27 January 16th, 2009 01:24 AM
Rim Question. 05bluestang 99-04 5 December 18th, 2008 01:52 PM
Rim Question Black01 99-04 7 December 18th, 2008 07:46 AM
Rim Question 90Stang 2005 - 2010 0 January 17th, 2008 07:25 PM
rim question notsoslo5.0 5.0 Mustangs 2 July 31st, 2006 05:16 PM
