will they hit??
Old February 3rd, 2009, 12:05 AM   #1
phxstang's Avatar
2004 mustang v6
phxstang is on a distinguished road
will they hit??
Ok for my next mod I plan on getting mac LT's and since I have a 2" drop im wonder if they will hit or sit to low ?if you can please post some pic of how your LT's sit??
Thanks
-Cold air intake
-Dual magnaflow exhaust
-2" dropzone kit
-Caster and camber plates
-Weight reduction
-12000k HID
-Smoked tail and headlights
Old February 3rd, 2009, 12:22 AM   #2
Dansby's Avatar
Dansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of light
Send a message via AIM to Dansby
They will be close, but you really wont know until you get them on the car. I'm about to drop my car and its going to be very close...thats running an o/r x.
Old February 3rd, 2009, 01:04 AM   #3
03MachMe's Avatar
2003 Mach 1 Mustang
03MachMe is on a distinguished road
it will be low for sure dont plan on going over any speed bumps but shouldnt be much worse than you are now
mostly stock
8.2@83 1/8th
Old February 3rd, 2009, 11:37 AM   #4
phxstang's Avatar
2004 mustang v6
Well I live in some apartment and its full ob speedbumps....
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old February 3rd, 2009, 11:46 AM   #5
Stang187 is on a distinguished road
if and when you do get them on and they hang low, cut and weld the longtubes and mid pipe together and they will sit higher. My driver ones hung a bit lower than my passenger and I didnt even do a drop on my car and it always hit the bumps depending how large the bump was. For the bigger ones I had to go over then inch by inch in slow motion to not hit them with the driver longtube, it was close though. Since they were cut and welded together I have had no speed bump probs.
Old February 3rd, 2009, 11:48 AM   #6
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
They do go lower. I would say, crawl under the car with a tape measure and give yourself 2 or 3 inches so you can see the worse case scenerio. Measure toward the ground from your collector and from any other point just to give yourself a good idea. Dansby's right though...they will sit different on every car. Thats why I say "assume the worst case" by expecting 2 to 3 inches.
also, do it when the exhaust is real hot after driving it for awhile because its always fun to get burnt by the exhaust!
Old February 3rd, 2009, 01:39 PM   #7
phxstang's Avatar
2004 mustang v6
Ok ill do it today we I get home from work..
U said do ir when it real hot right!!!
Lol
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old February 3rd, 2009, 02:18 PM   #8
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
lol first it wont be lower than your setup right now.. the hangers still should fit the same way.. 2nd you might scrape if your land is as bad as LA. i got my mid pipe remade yesterday cause it was scraping to hell. third it will sound sexy
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old February 3rd, 2009, 07:29 PM   #9
JASonic's Avatar
iTrader: 20 reviews
WHAT? Youngin...are smoking the good stuff again? (If you are, please send some to me cuz I need it) The collector will be lower on most cars...at least that Ive seen.
Old February 4th, 2009, 01:44 AM   #10
1964 Mustang Coupe
64SoCalStang is on a distinguished road
Send a message via AIM to 64SoCalStang Send a message via MSN to 64SoCalStang Send a message via Yahoo to 64SoCalStang
Long Tubes with a 2" drop will put the collectors about 2.5" off the ground. Clearing speed bumps without scraping will be difficult, if not near impossible. I've seen it done though. You will just have to really watch the road and pick your route carefully.
Dunn
Old February 4th, 2009, 01:51 AM   #11
phxstang's Avatar
2004 mustang v6
well i was hopeing to get some under the car pic of LTs
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old February 4th, 2009, 02:04 AM   #12
Hip Hop Artist
Youngin's Avatar
Byebye V6~
my friend has kook's LT headers on his s197 3v but i believe it looks the same
Old February 4th, 2009, 08:11 AM   #13
JASonic's Avatar
iTrader: 20 reviews
Ahhh, Kooks. I've only seen the MAC's. (Youngin, you need to hurry and put some new music out in the clubhouse)
Old February 4th, 2009, 11:13 AM   #14
Hip Hop Artist
Youngin's Avatar
Byebye V6~
extremely hard right now.. life is moving real quick and time is not of the essence right now my friend. but your right couple of the things i need to get done for the song. will try and make some time
Old February 4th, 2009, 11:44 AM   #15
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
Thanks
No they won't hit. I have Eibach Sportlines and Mac LT's:
Just over 2" clearance at the bottom of the flange on the collector pipe.
p.s. You need to treat most speed bumps like stop signs or you sill scrape.
ModdedAutos
1999 Mustang V6
Old February 4th, 2009, 11:59 AM   #16
Hip Hop Artist
Youngin's Avatar
Byebye V6~
lol whenever i see a speed bump i reverse and find another route lol... and i avoid parking in lots and try to avoid dips/potholes
Threads Similar to: will they hit??
Oh $hit! 97Cobra Videos 13 August 16th, 2008 11:54 PM
I hit 5k G.T. Rags The Clubhouse 49 May 9th, 2008 12:28 AM
hit 15.6 SantanielloITA Drag 1 November 7th, 2007 06:56 PM
would you hit it? 232stang The Clubhouse 46 June 10th, 2007 01:47 PM
already got hit yojoe600 99-04 32 March 22nd, 2007 10:22 PM
