1996 ford mustang
spark plugs????
what kind of spark plugs should i put in my car its s/c at 10 psi
and what gap should i set them to ???? i keep blowing up the motorcraft ones ...... |
[8MINUS2]
Tell us more info about your car.
The George Forman of Keepers
I was told by alot of guys that Bosch run like shit in a 6? You say they've done well in your car????
i use ngk
i just like them... they arent too expensive. i use them in my jet ski also
There are some real reasons why Bosch arent as good for 232's but I cant remember them. It may be the difference between iridium/copper etc. I just cant remember. I will take a second to search the forums.
#8 | |
2003 V6 Mustang
14.2 @ 96
These are good. |
Whatever it originally would be
ngk tr6. Good if your supercharged. I got mine from sparkplugs.com because the shops around here were charging like 90 bucks or somethin, yea i spent 29 on 8, thats with shipping.
![]() MILITARY CREW ANTI ILLEGALS CREW FOUNDER |
Using my Bonneville knowledge, I advise against platinum spark plugs. Stock Bonnevilles are all right with platinum plugs, but once you take down the pulley size, the plugs suck and ruin themselves very, very quickly. Irridium is highly recommended, but copper is a great fallback when you don't feel like spending more money. I use NGK irridium plugs, but NGK copper ones will work too.
What is the stock heat range? Or, what's the recommended heat range for a supercharged 3.8? I recommend TR55 (not TR5) plugs, but it really depends on the stock plug.
![]() 94 Bonneville - Turbo L67 & 6-speed manual project car 99 Bonneville - Tuned, aluminum UIM, ported LIM, bigger throttle body, no EGR, no evap, no cat, and a fender well intake I'm helping my friend mod his 2000 3.8 Mustang. It's fun. |
#11 | |
[8MINUS2]
This is the worst possible spark plug you could buy PERIOD.
![]() Hi, You can call me Kyle Last edited by ESG-642T; February 14th, 2009 at 02:51 AM. |
02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
What's a good gap for a stock setup, then what adjustments should be made when going s/c or NO2? I'm curious cause Im stepping down to a colder NGK TR6 for my nitrous setup (75 shot, big whoop) but Im unsure of a good place to start for gap.
If u s/c should u stay in the stock heat range and add gap? Again, I'm just curious for the s/c guys... |
The soul stealing Ginger
Bosch actually gave me a misfire when i put them in. took them back and got ngk coppers.
![]() Cosmetic: Vent-visors, Pioneer Bluetooth Radio Deck, 17" Cobra Alloy Rims, HID 4500k 55watt setup, Chrome Headlamps 15% Tint, Red sway bar Performance: CAI,Mac-Longtubes, H-pipe, Flow 40s, NO CATS Diablo Tuner, Rear Sway bar |
Was it because they grounded to the block or something? IDK...I cant remember the reason why so many people had problems with them in American cars. I know any of the "multi" tip kind have a had a history of breaking off and ending up in the engine.
The problem with platinum plugs in boosted applications is that they melt, pretty much. Copper and irridium are the only way to go. How hot is the Mustang's spark? See if you can go with an MSD ignition coil. I suggest a 55 gap, but it's a shot in the dark.
[8MINUS2]
MSD ignition coil ...
![]() If your running a s/c go 1 heat range colder ngk tr6 mine were gapped 35
#17 | |
![]() plats are no good for boost!
What's the issue with MSD coils? Are the stocks already hot enough? From the suggested 35 gap, I don't think they are.
I heard a lot about the E3 spark plugs, no need to set a gap, better spark for a better burn. They are about $6 each.
[8MINUS2]
unless your making a ton of power you don't need a DIS-4 , I don't think _J_ is even using one.
Threads Similar to: spark plugs????
| the new E3 spark plugs? | 71mustang06 | 2005 - 2010 | 1 | October 15th, 2008 09:31 PM |
| spark plugs | Divan | 5.0 Mustangs | 7 | July 16th, 2008 11:51 AM |
| Spark plugs | AnFking6908 | V6 Mustangs | 29 | April 26th, 2008 01:31 AM |
| Spark Plugs | 2000Mustang | V6 Mustangs | 5 | July 31st, 2007 04:48 PM |
| spark plugs?? | jmansracerocket | 99-04 | 1 | July 22nd, 2007 10:42 PM |
