Chris's 4.2/4.3L V6 turbo build - Page 2
LinkBack (8) Thread Tools
Old February 8th, 2009, 06:26 PM   #21
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
Originally Posted by Avaric3 View Post
i think an 8.8" is in order in the near future
Soon, I will put to the test the 7.5 with a detriot tru-trac and 28spline mosers
with my car i'd assume and hope it can do low 11s high 10s
before i touch the fuel and bigger turbo
Originally Posted by poindexter18 View Post
But which of the two is stronger, the zoom or the spec? Sometimes you gain weight for strength and I think strength is gonna be a super-must-have for you and that demon you're making. LoL. Watch the spec be lighter AND stronger and you get pissed at waiting for the mail.
I'am unsure both should be equal...
When i get more money later the tranny has to come out anyway to change the syncros. depending how i feel the clutch i'll change it then
Originally Posted by 94v6blkndred View Post
daaaamn son...thats gnarly as helll...cant wait to see it all done...i know kinda late on everything..havent been one in months it feels like..good luck
thank you
Originally Posted by Steam View Post
Looks good man! Post up updates soon
thank you
Originally Posted by Youngin View Post
8:5:1 compression? wow ...
and honestly you have to tell me which banks your robbing or how your playing your stocks.. very nice tho again.. its gonna be a bit for me to get my forged block
lol iam going paycheck to paycheck.
new promotion at work helps to plus online orders and local porting and polishing as well as side jobs
[SIGPIC][/SIGPIC]
Acmillr loves me
Old February 14th, 2009, 12:38 AM   #22
00 V6 & 09 GT
Block and head is back from the machine shop
pictures tomorrow
build starts next week
head flow
intake-235cfm
exhaust-150cfm
sticking with the camshaft that i have for now
[SIGPIC][/SIGPIC]
Acmillr loves me
Old February 14th, 2009, 01:54 AM   #23
white03v6's Avatar
2003 V6 Mustang
Too long@Too slow
white03v6 is just really nicewhite03v6 is just really nicewhite03v6 is just really nicewhite03v6 is just really nice
i cant wait to see some numbers and pictures!
Old February 14th, 2009, 01:57 AM   #24
2000 Mustang 3.8
radomirthegreat is on a distinguished road
Send a message via AIM to radomirthegreat Send a message via Yahoo to radomirthegreat Send a message via Skype™ to radomirthegreat
What's the stock piston's compression ratio? Is it lower or higher than 8.5:1?
Old February 14th, 2009, 02:24 AM   #25
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
Higher
Hi, You can call me Kyle
Old February 14th, 2009, 02:28 AM   #26
2000 Mustang 3.8
Since the 3.8 is naturally aspirated, does it then have a 9.5:1 or 10.0:1 compression ratio? Chris, which turbocharger are you using? Something in the 60mm range?
94 Bonneville - Turbo L67 & 6-speed manual project car
99 Bonneville - Tuned, aluminum UIM, ported LIM, bigger throttle body, no EGR, no evap, no cat, and a fender well intake
I'm helping my friend mod his 2000 3.8 Mustang. It's fun.
Old February 14th, 2009, 10:34 AM   #27
stangcharger's Avatar
stangcharger is on a distinguished road
Send a message via AIM to stangcharger
9.3:1 ratio.
That's what i have but the problem you run into which J greatly informed me is it limits you to how high you can go on pump gas. stock ratio will let you go to about 540rwhp on pump gas before you have to go to race fuel. the 8.5:1 ratio really opens doors and allows somewhere in the 700+rwhp range. i forgot exactly.
however 500rwhp is my goal with this p1-sc procharger. this build though however has a huge goal in mind and will need 8.5:1 compression. This will just make it easier and not much power is lost on our engines with the compression difference.
436rwhp/378rwtq tuned by HPP
www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com
Old February 14th, 2009, 06:16 PM   #28
2000 Mustang 3.8
What's the stock bore on the 3.8? You can go down to 8.5:1, but then you can over-bore a bit to get some more compression. You may make it up to 8.6:1 if you can bore enough.
Old February 14th, 2009, 06:24 PM   #29
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Originally Posted by stangcharger View Post
9.3:1 ratio.
You know that wont ever happen.
Old February 14th, 2009, 06:28 PM   #30
2000 Mustang 3.8
If you get a smaller charger, you can keep stock compression. It would help keep the charger in its range of efficiency. Either way is possible. Why wouldn't you be able to get to 500 WHP? That or more is what I'll get with my turbo Bonneville that I'm building up. Seems possible as long as you keep pouring money endlessly into it.
Old February 14th, 2009, 06:30 PM   #31
SleeperStang88's Avatar
2000 Mustang V6
need to run at track
SleeperStang88 is on a distinguished road
ssstang, im very confident that stangcharger could hit over 500 rwhp with his s/c that he has......it will be tough but im sure itll happen, and even if he cant make it that high with that particular s/c then he can go from a p1-sc to a D1-sc which is much higher rated for hp
Old February 16th, 2009, 01:14 AM   #32
00 V6 & 09 GT
with a p1 s/c it will be very hard. the SSX intake will greatly help him though.
either way s/c's on these cars are brutal, the more power you demand the more power THEY demand which means it wont be as efficient.
9:31:1 or 9:39:1 is the stock compression ratio.
The stock 3.8 rods are garbage and frail but no one intended it to handle gobs of power. although it worked for 439rwhp with me.
CURRENTLY I'am using a SC44 turbo which is a little bigger then a Pt57 and similar to a 60-1
it has a .68a/r
in the future that will change
stock BORE is 3.810 (belive thats piston Diameter.)
Pistons I personally went with are .030 over= 3.840 pistons
Total seal rings
the block you CAN go .060 over though which someone has done
but compression rating has nothing really to do with bore...
compression ratio is more piston height, dish, and cylinder head
if you mill your heads down .02 then you've increased your compression
My pistons as you can see have a decent size dish i think its 16 or 18cc
bore will not effect compression ratio
[SIGPIC][/SIGPIC]
Acmillr loves me
Old February 16th, 2009, 01:24 AM   #33
2000 Mustang 3.8
Awesome info. What happened to your 439 WHP bottom end?
If you go from 3.81 to 3.84 or 3.87 pistons, you will have .03 or .06 inches of more piston diameter. Your compression ratio with an 8.5:1 piston may then go up to 8.51:1, maybe. It does increase the compression just a tiny bit more. Definitely, getting the heads milled down does help a whole lot more. I just thought I might mention the slightly increased comp, but I do understand it's barely noticeable.
Old February 16th, 2009, 01:48 AM   #34
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Have either one of you been around here long enough to know shit? I guess not.. Phil and Keith(novi2k) can't hit 500hp do you think a p1 is going to hit 500? Even Gary was having trouble touching 500rwhp with the F1 procharger. And Phil has sucked every inch of hp out of his motor, and his C&W upper intake. - Now back to chris and his build which should make 500 easy -
Old February 16th, 2009, 02:00 AM   #35
2000 Mustang 3.8
I guess I haven't been around here long enough to know that you get diminishing returns on money poured into your car.
I was writing to Chris when I said he could retain stock compression and go with a smaller charger.
Old February 16th, 2009, 02:14 AM   #36
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Yep spend money on a smaller turbo when your chasing higher hp goals in a street car on pump gas!
We don't have a facepalm smiley do we?
Old February 16th, 2009, 02:42 AM   #37
2000 Mustang 3.8
I asked what size he's using now. The Precision SC44 is easily capable of taking smaller engines beyond 500 HP, but in this case it's too small for that much horsepower. If he were to have had a large turbo now, I would have lucked out in advising him to go with a smaller one or keeping that one and stock compression.
You should be glad there's no facepalm smiley here. With the kinds of posts you have been making here, you would be by now sick of seeing it all the time.
Old February 16th, 2009, 02:56 AM   #38
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
Yeah no, you realize chris isn't responding to you because and I quote "itschristorres8 (12:12:33 AM): lol im just not going to respond to him
itschristorres8 (12:12:46 AM): i have no time for stupidity or ignorance"
Later.
Old February 16th, 2009, 03:18 AM   #39
2000 Mustang 3.8
Sometimes different ideas are seen as stupid and/or ignorant. I'm not the one building a 500 WHP Mustang, so my consequence if I'm ever stupid or ignorant in this thread is minimal if anything. Chris is building a heavy duty Mustang, and if he doesn't consider all possible options, he faces a ton of consequences involving money, time, knowledge, etc. I'm sure he will reach his goal, but there's no reason to consider opposing viewpoints as stupid & ignorant.
I don't think anything bad about what he's doing, and he's actually doing it. I'm just talking about different options, and already people think I'm wrong. It's his thread. Of course he gets to decide if he's going to respond or not. Eventually though, if he keeps thinking other ideas are so dumb, those with other different ideas will return the favor.
Old February 16th, 2009, 10:04 AM   #40
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 12 reviews
Chris knows what he is doing, and I am sure he has considered all options.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/108643-chriss-4-2-4-3l-v6-turbo-build.html
TMA Turbo Race kit for sale This thread Refback February 24th, 2011 10:33 PM
TMA Turbo Race kit for sale This thread Refback November 27th, 2010 10:17 PM
TMA Turbo Race kit for sale - 3.8 Mustang Message Board This thread Refback December 29th, 2009 07:48 PM
TMA Turbo Race kit for sale - 3.8 Mustang Message Board This thread Refback December 27th, 2009 10:28 PM
TMA Turbo Race kit for sale - 3.8 Mustang Message Board This thread Refback December 27th, 2009 10:17 PM
TMA Turbo Race kit for sale - 3.8 Mustang Message Board This thread Refback December 27th, 2009 10:16 PM
fuel pumps, 60lbinjectors,boost-a-pump-ported heads & cam - 3.8 Mustang Message Board This thread Refback September 9th, 2009 03:36 PM
MySpace.com - External Link Alert This thread Refback May 17th, 2009 05:26 PM
Threads Similar to: Chris's 4.2/4.3L V6 turbo build
3.8 V6 Turbo build overview TurboLX General Tech 20 November 15th, 2011 02:45 PM
S.W. Customs V6 Turbo (build) Eds32vM1 V6 Mustangs 88 February 20th, 2010 06:14 PM
My turbo build 98 cobra 4V / SVT 5 June 16th, 2008 01:19 AM
Chris's V6 Turbo thread itschristorres8 V6 Mustangs 78 March 24th, 2008 08:26 PM
chris's turbo post is ruined. 1LOUDGT The Clubhouse 90 September 1st, 2007 08:13 PM
