1998 V6 Gauge cluster???
Old February 5th, 2009, 02:21 PM   #1
19Whitedevil98's Avatar
1998 V6 Mustang
19Whitedevil98 is on a distinguished road
Exclamation
I recently bought a gauge cluster off Ebay and was doing research on how to install it and people keep saying when you swap it that it wont start because of some PATS shit is this true for 94-98 models? Or is it just the 99+ ones that do that?
http://i60.photobucket.com/albums/h36/HAWTF/Mustang/1-6-11018-2.jpg
Old February 6th, 2009, 02:07 PM   #2
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
Its true, but as long as you dont turn the car on or have the negative terminal connected that should be fine.
Old February 6th, 2009, 02:53 PM   #3
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
you mean as long as you don't have the negative terminal connected while doing the swap right?
Old February 7th, 2009, 02:56 AM   #4
1998 V6 Mustang
So what he is saying is that if I don't have the negative terminal connected while doing the swap that I wont have any issue with that gay PATS??
Also I found this link and he said he had no problems with the swap
LINKY
Old February 7th, 2009, 03:01 AM   #5
2000 Mustang v6
That's what I was asking fastpony. I just want to make sure you have crystal clear instructions before attempting the swap. The last thing we want is for you to put the car in limp mode trying to do such a simple swap. Let's see if fastpony can clear up his earlier post a bit.
Old February 10th, 2009, 12:47 AM   #6
1998 V6 Mustang
BUMP
Anyone? need more advise/help.
Old February 13th, 2009, 02:31 PM   #7
1998 V6 Mustang
Ok I put the gauge cluster in and it worked the pats did not give me problems with starting it, All the gauges seem to work BUT the temp gauge which is bottomed out below HOT and my gas gauge shows less gas then what I have in it. And I think the oil pressure gauge is not 100% but I don't give a shit about that I am just happy that the speedo is accurate now and I have lower miles hahaha. But back on topic I need help/advise with the temp and gas gauge, is there anything I am suppose to do any thing I can try to make it work?????
Any help is a appreciated.
Threads Similar to: 1998 V6 Gauge cluster???
Gauge cluster mannymustang Audio/Video 3 September 12th, 2010 06:28 PM
Gauge Cluster ECUSVT31 4V / SVT 15 July 15th, 2008 10:43 AM
GAUGE CLUSTER BROKINARROW 5.0 Mustangs 8 October 5th, 2007 06:17 PM
gauge cluster coreyfitz 94-95 2 April 14th, 2007 06:37 PM
swapping '95 V6 gauge cluster to a '94-'98 GT cluster? Alocatelli V6 Mustangs 3 April 4th, 2007 02:38 PM
