Transmission flush?
I remember reading awhile back ago that doing this might just unplug any leaks...my car is a 98 stang and has about 127k miles on it good idea or bad to do flush? also i've noticed its starting to take just a little longer to start up in the cold weather.
one more thing the only thing i've done consistantly since i got the car (100k miles when first bought) is oil changes what other changes should i get checked out? |
Zoolander
04 Cobra #2260/3768 1/820
fuel filter, clean out fuel injectors, i would seafoam it, and spark plugs. Thats a good start with getting stuff done. I would post more, but kinda arguing with the girlfriend. So once thats done I'll help a little more.
2003 V6 Mustang
14.2 @ 96
I think the leaking thing only applies if its never been flushed before and over 100k miles. So if your tranny has never been flushed before I dont think I would do it. But I dont really know for sure either.
The soul stealing Ginger
why a total flush and not just a fluid and filter change?
#5 | ||
what else is there besides doing a total flush to your tranny? and ya i think that fuel filter is going to need getting change |
2002 Mustang V-6
15.8 @ 89 mph 2.4 60' siezed R-calipers
if the trannys never been done before dont touch it, fuel filter, plugs, wires, cap, etc
Fuel injector cleaner is almost useless, the gas itself removes what ever build up there is, but nothing will remove the particles that clog each individual fuel injector filter. IMO it is much more worth it to take out your fuel injectors (involves removing upper intake for easy access), take them to a shop that does that and have all new filters and o-rings on the injectors replaced, and checked for flow match. I had mine done 6 injectors for $50... They showed me the filters that were inside the injectors and they were shot and clogged.
The ones who never shut their mouths, never learn anything in life. |
#8 | |
1998 V6 Mustang
And you should probably flush your cooling system and change your differential fluid, also change your spark plugs, pour seafoam down your brake booster line and let it sit for 30 mins that cleans out your car pretty good and its fun to do . And if you want it to start better in the cold put SYN 5W-30, That's what I put in mine and my car started right up after sitting outside in -20deg for a day.
i forgot to mention, Wal-mart has this thing where they put something through the engine of the car, and spray the fuel injectors directly, i think it cost like 40.00 here where i live.
lol i was unaware that walmart had an autocenter! also guys whenever i do braking at about 60mph+ my steering wheel starts to shake....now i did just get new tires from costco (BFGoodrich traction T/A) wheel balancing/putting nitrogen in tires was included...only thing i can think of is allignment issue? i had my front 2 done less then a year ago.
I wouldn't be able to say for sure because at the same time I had that done I had also cleaned out a 1/4 inch in circumfrence of sludge out of my lower/upper intakes, and cleaned the MAF. I went from 13 mpg to 16 mpg so somewhere in there having the injectors cleaned did something for an increase.
The shop I had it done is the biggest turbo/diesel/injector shop in town for 20+ years, and these guys said the injectors were in serious need of service so it was a good thing I brought them in.
1998 V6 Mustang
My car does that to when I try to stop. I would have to say that it is most likely your brake rotors are shot. I know mine are messed up they are getting worse to the point it does not want to even stop anymore and the steering wheel shakes harder.
I would just replace all the transmission fluid by draining the convertor (there is a plug in the convertor to do that) and dropping the pan. Also replace the filter. I don't think that would do any harm. I would recommend Mercon V fluid from the Ford dealer.
Threads Similar to: Transmission flush?
| radiator flush | sivart | 5.0 Mustangs | 14 | December 5th, 2009 04:42 AM |
| best way to flush radiator and all?? | BakerFX4 | 99-04 | 11 | February 11th, 2009 06:40 PM |
| Radiator Flush | MustangMo | V6 Mustangs | 12 | June 6th, 2007 06:50 PM |
| power steering flush | acg | 5.0 Mustangs | 6 | May 26th, 2007 03:51 PM |
| I NEED A... Radiator flush | El_Cangri | V6 Mustangs | 13 | May 18th, 2007 02:10 PM |
