engine oil
Old February 10th, 2009, 09:50 AM   #1
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang is a jewel in the roughdgt_mustang is a jewel in the roughdgt_mustang is a jewel in the rough
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
engine oil
so my car has 115,000, i use castrol synthetic 10w30, Mobil makes this oil called 0w30, it says on the back that it exceeds 5w30 and 10w30, does that mean its okay to use 0w30 as a substitute for my 10w30? Castrol just came out with the same thing, called castrol edge, this oil comes in a 5w40 and 10w60! im just curious about, i take engine oil in my car more seriously then i do actual cleaning of the car...and you should see the shelf of cleaning parts for my car....ill post a pic...
Castrol EDGE
Get another job, get 2 more jobs, get your own place, work, live, fuck, eat, life, happy.
Old February 10th, 2009, 12:41 PM   #2
phxstang's Avatar
2004 mustang v6
phxstang is on a distinguished road
I also use castrol syn 10w30 I have 90k miles on my car.....should I keep usein the same or what do you guys recomend
-Cold air intake
-Dual magnaflow exhaust
-2" dropzone kit
-Caster and camber plates
-Weight reduction
-12000k HID
-Smoked tail and headlights
Old February 10th, 2009, 05:57 PM   #3
2001 Mustang 3.8l
i had one guy come into work the other day and bought 0w30 for his car, it had lke 122,000 miles on it, he said that since it said exceeds 10w30 on the back that it was ok, im not sure about it but all this time im thinking that 10w30 is better for a high mileage car, anyone else?
Old February 10th, 2009, 07:38 PM   #4
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
You need to understand the way the numbers work.
First off the first number is the viscosity of the oil on cold starts or it being cold...IE NOT engine temps. The lower the number the lower the viscosity...meaning in colder climates you want a lower number, hotter climates, you want a higher number, it helps in cold climates with cold starts, as the motor will turn over easier when it is below freezing. The 'W' doesn't stand for "Weight" like most think. It actually stands for 'Winter'.
The second number is the viscosity of the oil when warm or at operating temps. You want to get away with the thinnest oil you can use without causing engine damage or excessive wear. Whatever it calls for from the factory is what you should use. They set the motor up for a certain oil and I have actually seen dyno graphs and test where the motors have lost power because they run a different viscosity oil than recommended by Ford.
I run what my 710 cap tells me to. 5w-20.
Hope that helps.
Old February 10th, 2009, 08:44 PM   #5
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
lmao 710 cap lol
i know where you can buy one
lol
[SIGPIC][/SIGPIC]
Acmillr loves me
Old February 10th, 2009, 09:06 PM   #6
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
Originally Posted by itschristorres8 View Post
lmao 710 cap lol
lol
I've been stock piling them. They are RARE!
Old February 10th, 2009, 09:46 PM   #7
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ Well just giving you a heads up. Kinda sounded like an overall question...just wanted to give some info.
Old February 10th, 2009, 09:57 PM   #8
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
On my last oil change, I went with the Mobil One Synthetic (I use the recommended in the winter here in FL because the temps are average...in the summer I use one step heavier than recommended). Anyway, I had been running Pennzoil Synthetic. About 4 weeks into the Mobil One, I developed a sticking lifter. I thought Mobil One was supposed to be the best? Now I know lifters can get sticky from alot of things but it was weird that it happend after the Mobil One was put in. I used 3/4 bottle of Marvel Mystery Oil or whatever thats called and it nearly eliminated the sticking.
Next oil change, Im looking for a new oil. Im going to check out the castrol. The only other thing is that Ive been told that its bad on your seals and gaskets to switch away from Mobil One Synthetic after you start using it. Is that bullshit or truth?
Old February 10th, 2009, 10:38 PM   #9
ajm
Its bullshit. Just an old myth. Any of you guys tried the valvoline synpower. I know theres not to many valvoline fans on here (in the 99-04 section anyways) but I run it in a 4.2 with great results. Just a suggestion for people wanting to try something different.
As for the 0w30 comparing to 10w30 like someone else said you have to understand what the numbers mean. Once youre up to operating temps the 10w30 and 0w30 will be the same property wise. Whats different is the 0w30 will be thinner at startup.
Threads Similar to: engine oil
Engine Oil alabamastanger 99-04 20 January 25th, 2008 12:01 PM
oil change and engine cleanout mrnewall 99-04 6 May 16th, 2007 08:06 AM
engine oil? vacapro31 96-98 7 February 17th, 2007 06:34 AM
Engine Oil Question 4point6GT 96-98 5 October 8th, 2006 09:45 PM
Oil coming out of front of engine OTreborO General Tech 3 May 30th, 2006 11:27 AM
