cooling
Old January 25th, 2006, 05:56 PM   #1
zhunter is on a distinguished road
Send a message via MSN to zhunter
cooling
ok, i had to replace the coolant overflow tank because there was a hole in it. After gettin the new one put it, i put the coolant in with the appropriate mixture of water and coolant. i ran the heat so that the coolant would circulate, and the temperature gauge goes to the middle, but the heater blows cold air. I thought that the thermostat was out, but im not quite sure. The coolant doesnt seem to be circulating through the radiator, so i came to the conclusion that the radiator may be having some trouble. i just need to know what i should consider about this problem.
Old January 25th, 2006, 06:39 PM   #2
Roadhawg is on a distinguished road
Make sure you purge the air out of your coolant system by opening the high point.
It is located near/on the Thermostat housing.
2003 Mustang Mach1
1995 Thunderbird LX 4.6L;
1995 Mustang 4.2L; Eaton MPX Supercharger, 11.61 @ 118mph
Old January 25th, 2006, 07:18 PM   #3
Turbostang's Avatar
Turbostang is on a distinguished road
I would check the heater core. Put your hand on the line going in and if it hot, then check the line leaving the core. If it not hot then you have a blockage there.
I'd rather push a Ford, Than drive a Chevy
Threads Similar to: cooling
oil cooling systems wadepetersen V6 Mustangs 2 August 27th, 2007 12:45 PM
cooling problems RyanGT 99-04 30 August 16th, 2007 08:42 PM
Cooling Fan Stangzilla 5.0 Mustangs 23 March 25th, 2007 11:15 AM
Cooling Fan Problems rene9 96-98 6 September 26th, 2006 07:29 PM
