Wax on, Wax off
Alternator
So, My Alt is going out. I want to get a High Output one if feesable... any sites that sell them? Also, whats the safe zone for amps? I know stock is about 105.
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
2000 Mustang V6
need to run at track
![]() iTrader: 2 reviews
go to your local autozone and ask them and they can also test your alternator for free
Wax on, Wax off
I already had it tested, that is why I am looking for another one. Auto Zone only has a stock replacement that is 105 amps. I am trying to find one that is over that (High Output) and need to know a place I can get one, and a safe amp range.
Wax on, Wax off
The George Forman of Keepers
Ive seen 140's for sale. If I remember right, you have to replace some wiring and fuses from the stock setup when you upgrade.
High Output Alternator Hi Amp by HO MUSTANG HIGH 220 AMP OUTPUT ALTERNATOR 94 95 96 97 98 99 00 7761: 7771-220 AMP - STORE DB Electrical Starter-Alternator |
Wax on, Wax off
I found this one here:
MUSTANG 3.8L 200 AMP HIGH OUTPUT ALTERNATOR 01 02 03 04 8266: 8266-200 AMP DB Electrical Starter-Alternator combined with this wiring kit: FORD CHEVY HIGH OUTPUT ALTERNATOR FUSE BLOCK WIRING KIT 101: WIRING KIT-101 4 GAUGE- 6 FT - 250AMP ANL FUSE DB Electrical Starter-Alternator Now, my question is, will 200amps be ok for my car? I do not want to fry anything... Also, how hard is it to replace the wire goin from the altrenator to the starter (I think it goes there first) I have always noticed that wire goes up under and behind the engine somewhere.
I looked in my Haines and it doesnt look to hard. I was looking for an HO alternator at one time myself. I decided against it simply because I couldnt get enough info on "frying" shit and any other unwanted side effects. I dont have an aftermarket stereo or anything that really needs the juice. I was just feeling like the stock alt wasnt doing a good enough job. hopefully someone will chime in on this thread that has one or knows. Im curious too.
#8 | |
Wax on, Wax off
Another question... install... can it be done at home? I know its 2 bolts, Wire bolt, and the part I am unsure on; the belt.
#9 | |
2000 Mustang V-6
The soul stealing Ginger
^pretty much thats it for an install,
i would think that as long as you upgraded the wire and a fuse or two the other fuses would keep your shit from "frying". keep a variety pack of fuses on hand just in case. |
#11 | |
Wax on, Wax off
I decided to just go with a Std. one, gonna pick it up from Auto Zone today. It's $160 + $80 core.. so not to bad. I get the $80 back when I bring my old one back I belive.. right?
2001 Mustang 3.8L
The tensioner is a lever with a pully on it. On my 2001 V6 it is located on the passanger side of the engine (in the front, of course).
The automatic tensioner is one of the greatest things ever put onto cars. It makes changing/removing the drive belt easy as pie. Just pop a 3/4" rachet (no socket on it, just the square part of the socket wrench) into the square hole on the side of the tensioner and pull (or push) so it removes tension from the belt. Then, slide the belt off. Should take less than a min. Put a breaker bar on the end of your socket wrench to make releasing the tension even easier. Sometimes it can take a fair amount of force to release tension and the extra leverage really helps. Don't worry you can't break anything doing this, unless you try really, really hard and do something very stupid. Even then I don't see how you could break anything. |
Admanistrator
if you get a high performance alt., do you lose some hp with it?
Threads Similar to: Alternator
| Alternator | Iownastang | 5.0 Mustangs | 12 | January 25th, 2009 09:37 AM |
| Alternator? | jonnotch | 5.0 Mustangs | 4 | October 29th, 2007 07:25 PM |
| 3G alternator.... | Casper98GT | 5.0 Mustangs | 11 | October 2nd, 2007 05:16 PM |
| alternator | mustangman0001 | 5.0 Mustangs | 5 | September 20th, 2007 10:40 PM |
