Traction Control
Old February 17th, 2009, 02:47 AM   #1
2004 V6 Coupe
04stang123456789 is on a distinguished road
Traction Control
As you may have noticed there is a button to put traction control on or to turn it off. I bought my car with less than 20K miles and some mods on it and the traction control button does not work. If you push the button the light stays on. I can tell that I do not have traction control.
What could have caused this, and does anyone know of a way to fix the problem?
Old February 17th, 2009, 03:06 AM   #2
mooses is on a distinguished road
Unless it's been deactivated by a tuner, it is on by default when you start the car. When you push the button and the light is on, T/C is off.
Old February 17th, 2009, 03:07 AM   #3
2004 V6 Coupe
The problem is that the light is always on, when the car turns on the light is on. Maybe it was deactivated by a tuner.
Old February 17th, 2009, 03:07 AM   #4
bullitt5576's Avatar
2001 Bullitt
bullitt5576 will become famous soon enough
is your abs light on in the dash? is the light on the tc button lit and wont cycle when you press it?
there are a couple of things that it could be but you need to give more info to narrow it down some
edit: read the light is always on
MM NEW EDGE COBRA CREW #2
Old February 17th, 2009, 03:09 AM   #5
2004 V6 Coupe
The abs light never came on. And yes, the light will not cycle when I hit it. The light on the button just stays on thw whole time as I press it.
Old February 17th, 2009, 03:11 AM   #6
2001 Bullitt
it could be something as simple as a sensor on one of your wheels, or it may be that your rear end is messed up
if you have a friend with a tuner you *might* be able to have them plug it in to see if your t/c has been turned off with a tune
Old February 17th, 2009, 03:14 AM   #7
2004 V6 Coupe
I do not think it is the sensor because I can tell traction control really is off, so I will see if anybody I know has a tuner and maybe that will tell me.
Old February 17th, 2009, 03:17 AM   #8
2001 Bullitt
what im saying is that if one of the wheel sensors has gone bad it can turn t/c off and not allow you to cycle it on
Old February 17th, 2009, 03:20 AM   #9
2004 V6 Coupe
Ohh, okay. I will have it checked out. Thanks
Old February 17th, 2009, 12:19 PM   #10
2003 Mustang 3.8
slow
joparrett is an unknown quantity at this point
well in your other post you mention that it chirps into second gear.... plus the traction control is turned off.... my car does all of this and I have a tuner. I would imagine you have the same thing.. it isn't a bad thing, but to get it off I would say you will need a new ECU or at least a re-flash to stock at a dealer
Jordan | 2003 Mustang 3.8 | SCT Tuner by VMP | CAI | Flowmasters | ZEX 75 shot
Old February 17th, 2009, 01:34 PM   #11
Trick Tuners's Avatar
KB'd GT
It sounds like it was turned off in a tune, especially if it shifts hard. It might be a tune for 91/93 octane so make SURE that it does not knock on 87 octane. Here is a little info on detonation so you can make sure it never happens.
Detonation Explained
Old February 18th, 2009, 08:30 AM   #12
2003 Mustang 3.8
slow
did you buy the car of a private seller or a dealer?
--contact the original owner... He probably has a locked tuner around somewhere.
Old February 18th, 2009, 08:30 AM   #13
2003 Mustang 3.8
slow
and btw you won't be able to tell if it has been tuned simply by plugging a tuner in
Old February 18th, 2009, 03:27 PM   #14
2004 V6 Coupe
I got it from a dealer, but I ran a car facts history report and it said it was owned by one person, then repossessed and sold at auction to this dealership.
Old February 18th, 2009, 09:29 PM   #15
Admanistrator
v606er's Avatar
v606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to behold
off is more fun anyway! just look at it this way: you dont have to waste turning it off everytime you turn your car on!!!!
MAD Stangs #8
Old February 18th, 2009, 09:31 PM   #16
2004 V6 Coupe
haha yea I perfer to have it off, but I just wanted to make sure there wasnt an electrical problem, or some other kind of problem with the car... although it does help in the snow
Old March 2nd, 2009, 03:26 AM   #17
robinson427 is on a distinguished road
The car is already tuned. Don't waste your time having it checked out, just enjoy your tune
Old March 9th, 2009, 08:50 PM   #18
2004 V6 Coupe
I do not know if this is related to the traction control being always off, but now my service engine light come on every almost every time the car is in the snow or rain. Are the tires throwing the computer off when they spin? It only seems to happen when it is in the rain or snow. Does anybody know what the problem could be, because I do not have the time to get it checked right now?
Old March 10th, 2009, 06:34 PM   #19
2004 V6 Coupe
Anyone??
Old March 10th, 2009, 07:46 PM   #20
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
If your ABS sensors or computer are not working you will not have TCS or ABS and light will stay on letting you know its off.
Is your ABS light on your dash? Its a green wheel.
Threads Similar to: Traction Control
traction control? 03gtfirered 99-04 4 July 23rd, 2008 08:37 AM
Traction Control kdb30 Modular Mustangs 2 June 1st, 2007 03:54 AM
Traction Control stang94 5.0 Mustangs 0 December 7th, 2006 04:45 PM
Traction Control khartford Modular Mustangs 4 November 11th, 2006 07:54 PM
Traction Control MnrlGry01gt 99-04 6 October 22nd, 2006 04:27 PM
