Split Port??????
Old February 17th, 2009, 01:46 PM   #1
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
Split Port??????
Is the stock 2004 232 split port?
Old February 17th, 2009, 01:53 PM   #2
2000 Mustang V-6
BlkY2k is on a distinguished road
Yes it is.
Old February 17th, 2009, 02:29 PM   #3
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
Old February 17th, 2009, 02:45 PM   #4
JASonic's Avatar
iTrader: 20 reviews
Whats the difference? I dont really understand it.
Old February 17th, 2009, 02:53 PM   #5
goren813's Avatar
'00 3.8L & '05 4.6L
Browser Warning
Pretty good article that explains it and its centered around Ford.
Old February 17th, 2009, 02:54 PM   #6
goren813's Avatar
'00 3.8L & '05 4.6L
...hmm browser warning? it's an article at autospeed.com... dunno why it says that...
Old February 17th, 2009, 03:06 PM   #7
JASonic's Avatar
iTrader: 20 reviews
Nice article Goren. Its a bit over my head in places but it hits on another topic Ive been trying to research. They talk about the way the intake is "tuned" to the shock waves created. I was trying to understand the way the exhaust is tuned and never knew this theory was applied to the intake as well. It looks like alot of time and money were put into tuning the split port correctly.
Timing the pressure wave to arrive back at the valve when its open will result in more air entering the chamber. This shit will make my head hurt. Now in the exhaust, you want the pressure wave to to bounce back and hit the valve when its closed...I guess.
Old February 17th, 2009, 03:17 PM   #8
goren813's Avatar
'00 3.8L & '05 4.6L
Yeah the engineering behind it all is crazy ... and as far as what you are discussing with the exhaust, you're right with me with "I guess." Since I haven't gotten to the point of actually having the aftermarket exhaust I haven't delved into the sciences of it...
Old February 17th, 2009, 03:27 PM   #9
JASonic's Avatar
iTrader: 20 reviews
Hey, check this out Goren...its on the intake side but it this is easy to understand.
I copied it from an article------------------------------------------------------
The intake system on a four-stroke car engine has one main goal, to get as much air-fuel mixture into the cylinder as possible. One way to help the intake is by tuning the lengths of the pipes.
When the intake valve is open on the engine, air is being sucked into the engine, so the air in the intake runner is moving rapidly toward the cylinder. When the intake valve closes suddenly, this air slams to a stop and stacks up on itself, forming an area of high pressure. This high-pressure wave makes its way up the intake runner away from the cylinder. When it reaches the end of the intake runner, where the runner connects to the intake manifold, the pressure wave bounces back down the intake runner.
If the intake runner is just the right length, that pressure wave will arrive back at the intake valve just as it opens for the next cycle. This extra pressure helps cram more air-fuel mix into the cylinder -- effectively acting like a turbocharger.
The problem with this technique is that it only provides a benefit in a fairly narrow speed range. The pressure wave travels at the speed of sound (which depends on the density of the air) down the intake runner. The speed will vary a little bit depending on the temperature of the air and the speed it is moving, but a good guess for the speed of sound would be 1,300 feet per second (fps). Let's try to get an idea how long the intake runner would have to be to take advantage of this effect.
Let's say the engine is running at 5,000 rpm. The intake valve opens once every two revolutions (720 degrees), but let's say they stay open for 250 degrees. That means that there are 470 degrees between when the intake valve closes and when it opens again. At 5,000 rpm it will take the engine 0.012 seconds to turn one revolution, and 470 degrees is about 1.31 revolutions, so it takes 0.0156 seconds between when the valve closes and when it opens again. At 1,300 fps multiplied by 0.0156 seconds, the pressure wave would travel about 20 feet. But, since must go up the intake runner and then come back, the intake runner would only have to be half this length or about 10 feet.
Two things become apparent after doing this calculation:
The tuning of the intake runner will only have an effect in a fairly narrow RPM range. If we redo the calculation at 3,000 rpm, the length calculated would be completely different.
Ten feet is too long. You can't fit pipes that long under the hood of a car very easily.
There is not too much that can be done about the first problem. A tuned intake has its main benefit in a very narrow speed range. But there is a way to shorten the intake runners and still get some benefit from the pressure wave. If we shorten the intake runner length by a factor of four, making it 2.5 feet, the pressure wave will travel up and down the pipe four times before the intake valve opens again. But it still arrives at the valve at the right time.
There are a lot of intricacies and tricks to intake systems. For instance, it is beneficial to have the intake air moving as fast as possible into the cylinders. This increases the turbulence and mixes the fuel with the air better. One way to increase the air velocity is to use a smaller diameter intake runner. Since roughly the same volume of air enters the cylinder each cycle, if you pump that air through a smaller diameter pipe it will have to go faster.
The downside to using smaller diameter intake runners is that at high engine speeds when lots of air is going through the pipes, the restriction from the smaller diameter may inhibit airflow. So for the large airflows at higher speeds it is better to have large diameter pipes. Some carmakers attempt to get the best of both worlds by using dual intake runners for each cylinder -- one with a small diameter and one with a large diameter. They use a butterfly valve to close off the large diameter runner at lower engine speeds where the narrow runner can help performance. Then the valve opens up at higher engine speeds to reduce the intake restriction, increasing the top end power output.
Old February 17th, 2009, 04:16 PM   #10
goren813's Avatar
'00 3.8L & '05 4.6L
Makes sense to me, it explains the diagram that the article I posed had showing each side of the split port and everything. Really ingenious if you think about it, all about the power!
Threads Similar to: Split Port??????
windstar split port swap or port and polish winnie51189 V6 Mustangs 22 November 4th, 2008 04:04 PM
split port mannymustang V6 Mustangs 8 June 25th, 2008 12:50 PM
Single port VS Split port BDaily V6 Mustangs 22 April 24th, 2008 11:28 PM
Single Port vs. Split Port One Bad Sixxx V6 Mustangs 24 June 2nd, 2007 10:26 AM
single port to split port 94pacecarSVT V6 Mustangs 5 February 2nd, 2007 12:25 AM
