Discussing v6 to v8 engine swap in the V6 Mustangs Forum. im not sure if its been listed but you'd need everythin tuned, the electronics ...
Old January 8th, 2007, 09:05 PM   #21
SP00LIN V6
2000 Mustang V6
unknown @390
but you'd need everythin tuned, the electronics and computer flashed or tuned however that works
if your JUST KEEPING THE ENGINE STOCK a t-lok will do fine and an 8.8 rear end wont be needed
as far as everything else you'll need a new exhaust and headers and thats it
and w/e is missing with the engine
437rwhp and 402rwtq through a V6 on a stock bottom end
Old January 9th, 2007, 08:03 AM   #22
tnee_97stang's Avatar
well i just found out that im gunna be able to take the car with me to college but neways am i gunna need a whole new axle or just beef up my gears in the rear end? oh yeah and the tranny he has is automatic and mine is a 5 speed so im sure ill need a new clutch flywheel pressure plate etc. besides that everything i need is on the engine. its a complete assembly. headers and exhaust and shes good to go
imports are like tampons, every pussy needs one
Old January 9th, 2007, 05:18 PM   #23
SP00LIN V6
2000 Mustang V6
unknown @390
yea, you'll need what you've mentioned...if your keeping the engine stock for the rear axle you'll need just a 28spline traction lock diff and thats it really...gears are just another option that i really recommend
Old January 9th, 2007, 08:34 PM   #24
ok whats the difference between the lock diff. and new gears? and i probably wont do much to it other then polish and port the heads, throttle body spacer, tuner, and some intake parts. other then that im keepin it stock. im hoping to be around 300 hp by the time im done. and 4.10 gears are a possibility.
Old January 9th, 2007, 10:44 PM   #25
SP00LIN V6
2000 Mustang V6
unknown @390
k then keep your rear axle to a 7.5 the way it is..and throw the 4.10s and a t-lok in it.....the t-lok will make both your wheels spin
lose the throttle body spacer though..its worthless
Old January 10th, 2007, 12:30 AM   #26
idk dude.. that year of motor was putting out like almost 300 lbs of torque
isnt that alil much for the 7.5?
I beat a GT he says I wasted my money on a v6.
I beat a Mach 1 he says I only won cause he's stock.
I beat a Cobra.. well, needless to say he isn't talking, he's just pissed.
Old January 10th, 2007, 06:43 PM   #27
plus after i build it i should be pushing more then that. the new gearing might hold up better with the increased hp and torque. thanks btw chris im not getting the spacer.
Old January 10th, 2007, 10:09 PM   #28
SP00LIN V6
2000 Mustang V6
unknown @390
no prob
300lbs of torque at the crank maybe. the 7.5 can handle that
Old January 11th, 2007, 01:01 PM   #29
sweet. now all i need to do is get on him about gettin the motor to me and i can start cracking away at it. theyre are plenty of civics in my town ready to get showed up.
Old January 11th, 2007, 01:10 PM   #30
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
good luck with that... its a direct drop in right?? the only hard part is gonna be the computer bull shit that you have to put up with to make it all work together
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old January 11th, 2007, 01:17 PM   #31
yeah its just a drop in. i need to mod it out before hand though. ne advice on some upgrades because i want to have mostly performance parts on it since i have it out already and can rebuild it. i want the most power i can get but i kinda am leaning toward staying naturally aspirated.
Old January 11th, 2007, 02:46 PM   #32
2000 V6
Heads, and cams...Do the headers before the car goes in...basically do everything you want that requires a taken apart engine
2000 V6
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive crank pulley, SCT tune,
and a buncha cosmetic mods
Threads Similar to: v6 to v8 engine swap
Engine Swap Standardrift V6 Mustangs 13 December 29th, 2007 02:38 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 07:48 PM
Engine Swap help me out jtlogruss08 5.0 Mustangs 15 August 9th, 2007 08:43 AM
Engine swap V6 to V8. HELP Snapsoccer V6 Mustangs 30 May 17th, 2007 09:41 PM
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 32 April 8th, 2007 08:15 PM
