power steering pump/pressure switch
Old February 21st, 2009, 05:58 PM   #1
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
Can a bad power steering pump or "failing" pressure switch cause the car to stall or bog down under load?
Old February 22nd, 2009, 03:21 AM   #2
Triple A's Avatar
Triple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud ofTriple A has much to be proud of
i don't think the power steering pump would make your car stall. and i read on another forum that if the pressure switch does fail your car will stall because the oil switch doesn't keep the pump running. you can buy a replacement for like 15 bucks.
Threads Similar to: power steering pump/pressure switch
Power steering High Pressure Valve TOOLinYourFace V6 Mustangs 2 July 30th, 2008 04:28 PM
changing my power steering pressure line Iwannagofast 5.0 Mustangs 3 January 22nd, 2008 10:12 AM
changing power steering pressure line Iwannagofast 94-95 1 January 21st, 2008 10:51 PM
power steering pressure line Stang6899 General Tech 1 October 9th, 2007 06:45 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
