V6 RPM Miss (Temp Dependent) Plz Advise!
Old January 9th, 2007, 08:38 PM   #1
02 Mustang V6
13.605 @ 101.60
Garman91 is on a distinguished road
iTrader: 6 reviews
Hey guys,
I'm new here, just bought an 02 Mustang V6. Has a few mods already so I'm wondering what's all been done to the car. It has a MagnaFlow H Pipe setup, BBK 70mm Throttle Body w/ Swirl Adapter and BBK Cold Air Induction System. The problem I'm having is this:
Low throttle input (All RPM's) motor runs like a dream
Half & Full Throttle in Low & High RPM Range feels like its running excessively rich or has a cylinder missing
However these only happen once the motor warms up, at a fresh start in the morning, motor will scream for 15 minutes or so then start to act up.
This afternoon I checked & replaced spark plugs (None were fouled up), replaced Throttle Position Sensor (No help) and the air filter just because
If anyone has any ideas, please let me know because I can't figure it out. Someone suggested plug wires but why would that be temp dependent? Possibly a timing issue? Again, why temp dependent. Has anyone else ever experienced this? Is the throttle linkage on the throttle body miscalibrated? Thanks in advance - sorry for writing a novel, I like to be precise!
~ Garman91
Old January 9th, 2007, 09:01 PM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
sounds like the throttle body to me.
do you have any codes?
Old January 9th, 2007, 10:21 PM   #3
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
Thanks for the advice. No check engine light so I haven't checked to see if it's spitting out any codes. What's the best way to check it - shops want $50 just to plug in a little hand held reader, any better way?
Also had a suggestion of ignition system, want to stop spending money fixing the problem and start spending to make it faster Thanks again for any input!!
BBK Intake, BBK 70MM Throttle Body w/ Port Matched Upper Intake, BBK Shorty Headers, Magnaflow Exhaust, GT Tips, Eibach Sportline Springs, EGR Delete, Aluminum DS, 7.5 T-Lok w/ 3.73's, Centerforce Clutch, ZEX 75 Shot, Sniper Tuned
Old January 9th, 2007, 10:30 PM   #4
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
A bigger throttle body does nothing if you dont port match the upper intake...in fact it could hinder the cars performance
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old January 9th, 2007, 10:37 PM   #5
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
go to a parts store like kragens or autozone. they have scanners and will do it for free.
Old January 9th, 2007, 11:04 PM   #6
2000 V6
How would it read a code that isnt showing...I think they wanna charge him for a diagnostic
2000 V6 vert
Old January 10th, 2007, 04:06 PM   #7
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
I don't want to take it to a professional. Any other ideas? So far I have
Throttle Body Configuration
Plug Wires / Distributor
Anyone have any other ideas to try before I really burn some cash? Thx!
Old January 10th, 2007, 06:01 PM   #8
tnee_97stang's Avatar
tnee_97stang is on a distinguished road
im looking for similar problems online but cant find much. i know it cant be a miss fire in a cylinder because your check engine light would be on and flashing. you computer considers that catastrphic failure so it flashes but i agree with the above comment. it could be that the throttle body doesent match the port of the upper intake.
imports are like tampons, every pussy needs one
Old January 10th, 2007, 06:26 PM   #9
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
Well. My check engine light did flash and come on for the first night I owned the car. After that, nothing. As far as the throttle body - I have the spacer between the plenum and the throttle body that tapers the throttle body bore to that of the plenum. Why would that cause a hesitation? Would it prevent air flow when the butterfly is open wider that say a "crack?" Very possible explination! I'm looking into it w/ a buddy who has a 450HP Stang on Saturday, I'll post the results.
Update on the condition: Seems to happen when the motor is under stress regardless of temperature, just more prevelant once it heats up. If the motor is casually accelerating (Low throttle input) it doesn't happen. Any time the motor is pushed the studder occurs.
Old January 10th, 2007, 06:52 PM   #10
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
if it is your fuel mixture rich, it is probably the front pair of oxygen sensors or maf, or similar a/f ratio controller. misfire could be b/c it ran rich and fouled a plug... pull your spark plugs and see how they look.
ModdedAutos
1999 Mustang V6
Old January 10th, 2007, 07:29 PM   #11
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
check the thing for a tune.....
Old January 11th, 2007, 07:36 PM   #12
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
I replaced all 6 plugs and my buddy said they looked normal so I guess rich is out of the question
Take it to the shop for a standard tune up and see what the mechanic says? It's going to the shop for compression tests and general "checking out" on Tuesday - wish me luck!
Old January 11th, 2007, 09:39 PM   #13
2000 V6
Shouldnt rich or lean have a code showing
2000 V6 vert
Old January 11th, 2007, 09:46 PM   #14
14.79 @ 92.15
usually. it could throw a number of codes depending if it were timing or spark, a/f mixture (oxygen sensors, injectors, maf, etc.)
if it isnt throwing a code, check fluid levels and leaks or vaccuum leaks. if you have a vaccuum leak, it will run sluggishly, but it shouldnt be only at high rpms...
ModdedAutos
1999 Mustang V6
Old January 11th, 2007, 10:02 PM   #15
flames_blue is on a distinguished road
I was planning on getting a T body spacer then later a t body. are these kinda problems normal? and do you have to program the car after you put it on or is it like a normal bolt on?
we're like then an 's like and Im like :lala then we're like then Im like :award then he's like then everyones like you got then he's like I got Im like
Old January 11th, 2007, 10:11 PM   #16
2000 V6
normal bolt on but a TB spacer is useless. A bigger TB woulnt help unless you port the upper inake to match the size of the TB, otherwise it may hinder your performance
2000 V6 vert
Old January 11th, 2007, 10:25 PM   #17
what does that do and how much would that cost?
Old January 11th, 2007, 10:39 PM   #18
2000 V6
A TB with a ported upper intake would would allow more air into the engine...not too sure on the gains, or price...and the TB spacer will net you nothing
2000 V6 vert
Old January 12th, 2007, 12:42 PM   #19
how do you port the upper intake?$$?
Old January 12th, 2007, 05:46 PM   #20
02 Mustang V6
13.605 @ 101.60
iTrader: 6 reviews
All the spacer is good for is giving the 70mm butterfly clearance. Cant bolt the 70mm TB to the plenum cause the butterfly hits, spacer gives clearance.
Threads Similar to: V6 RPM Miss (Temp Dependent) Plz Advise!
Need Advise!! Please Kosinski 96-98 13 September 6th, 2007 09:38 PM
Need some advise... HellRazor 96-98 7 April 17th, 2007 10:45 AM
Need advise wingsmvp31 V6 Mustangs 15 January 12th, 2007 12:12 PM
Need Advise 88Horseman 5.0 Mustangs 2 January 5th, 2007 01:09 AM
thanks ..... now i need some advise niggadrew 5.0 Mustangs 8 August 27th, 2006 10:50 PM
