exhaust manifold problems
Old March 10th, 2009, 12:00 AM   #1
stephen has a spectacular aura aboutstephen has a spectacular aura about
We had a noise when the engine was cold that sounded to me like lifter noise. It turned out it was a cracked weld in the right exhaust manifold. After I took it out I could see evidence of leakage between two of the flanges that bolt up to the head and the pipe. When the manifold heated up it apparently sealed again. I replaced both exhaust manifolds and the noise is gone.
This is apparently a common problem on V6 Mustangs, so it's a good idea to check the manifolds if there is a loud rapping noise when the engine starts from cold.
Threads Similar to: exhaust manifold problems
Exhaust manifold gasket blkragtop 99-04 4 November 22nd, 2008 08:04 PM
Exhaust Manifold joe_shizzle V6 Mustangs 9 April 12th, 2008 01:38 AM
Stock exhaust manifold? Vinyl66 Classic Mustangs 33 March 13th, 2008 05:11 PM
intake manifold cracked... got a new one but havin problems 96gtstang&V6 96-98 11 November 7th, 2007 11:07 AM
exhaust manifold leak laser_red_3.8 General Tech 7 September 13th, 2007 10:33 PM
