need tranny help
Old March 14th, 2009, 07:21 PM   #1
phxstang's Avatar
2004 mustang v6
phxstang is on a distinguished road
need tranny help
ok so today wen i pulled out ov the driveway i noticed some oil spill..got off and realized it was tranny oil ,i jacked up the car and there isa lil crack in the oil pan fot the tranny..is it hard to replace?and how many trnny oil will i need if i change it?
-Cold air intake
-Dual magnaflow exhaust
-2" dropzone kit
-Caster and camber plates
-Weight reduction
-12000k HID
-Smoked tail and headlights
Old March 14th, 2009, 08:00 PM   #2
phxstang's Avatar
2004 mustang v6
do anybody know how to do this???help please
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 14th, 2009, 11:26 PM   #3
2003 V6 Mustang
14.2 @ 96
ewells2420 is infamous around these partsewells2420 is infamous around these partsewells2420 is infamous around these parts
Im no mechanic but im going to say. ....... oh I dunno ......
Buy new pan
unbolt old pan
bolt on new pan
profit.
Old March 15th, 2009, 04:33 AM   #4
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
RedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really niceRedDevilGT is just really nice
I don't know about the first part, but i do know you'll need 3 quarts of ATF. I just changed my fluid and thats how much it took.
01' V6: SCT tuned, Dual Flowmasters & H-pipe, 8000k 35w HID's, Steeda Short Shifter, BBK CAI, Eibach pro-kit, 3.73's and t-lok.
05' GT: SCT tuned, C&L Racer, FRPP cams, Pypes Pype Bomb's, Shorty Antenna, Painted Mirror covers, Decklid Panel
Old March 15th, 2009, 03:23 PM   #5
phxstang's Avatar
2004 mustang v6
well i went to every auto part store and they dont carry the trans pan
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 15th, 2009, 03:35 PM   #6
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
Sorry a little off subject, But PHxstang what area do you live at in phoenix? I'm in avondale
Old March 15th, 2009, 07:15 PM   #7
stephen has a spectacular aura aboutstephen has a spectacular aura about
You may have to go to Ford for the oil pan. It will take more like 4-5 qts of trans. fluid. I would recommend getting the fluid from Ford. I think the Ford gasket is better, since it is a reusable rubber gasket. You probably should also replace the filter if it hasn't been done recently.
To remove the pan just take out all the bolts but the corner ones. Then loosen the corner bolts and try to get most of the fluid into a drain pan. Likely you will spill some.
The pan bolts are torqued to ~10 ft-lbs.
Old March 15th, 2009, 08:37 PM   #8
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
3, I think the torque converter itself almost holds 3....
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old March 16th, 2009, 12:34 PM   #9
phxstang's Avatar
2004 mustang v6
i live by the i10 off 43 ave
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 16th, 2009, 12:35 PM   #10
phxstang's Avatar
2004 mustang v6
ok ive been lookin and i dont seem to find a how to do it ur self for the trans pan replacemnet
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 16th, 2009, 05:01 PM   #11
I explained how to remove it above.
Perhaps the amount of fluid required depends on the year, but for a 99 Mustang, with the trans and converter both drained it took about 10 qts to refill it.
Old March 16th, 2009, 05:31 PM   #12
SG
RedDevilGT's Avatar
2005 Mustang GT
2001 Mustang V6
O cool. Maybe I'll see ya cruisin around one day
Old March 16th, 2009, 06:55 PM   #13
Here's a fancy cast aluminum oil pan if you want to upgrade.
1993-1999 Ford Mustang - B&M Transmission Pan - Aluminum Cast
Old March 17th, 2009, 05:51 PM   #14
phxstang's Avatar
2004 mustang v6
well send me a pm and ill give u my number and we can roll some time
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 17th, 2009, 06:25 PM   #15
ajm
Very simple. Get you a 10mm socket, extension and ratchet. Remove the 14 bolts around the pan, put the new one on and reinstall all 14 bolts torquing to spec. If you dont have a torque wrench just get them pretty snug. Should take 4-5 quarts of fluid. Your best bet is to put in 3, start it up and let it run for a bit, check the fluid, add more if needed. Once you see some fluid on the bottom of the dip stick let it sit and get to operating temp. Add 2oz's at a time waiting a 10-15 seconds between checking the fluid, continue until you hit the full mark. Go for a cruise and check the fluid again, add more if needed.
For needing a pan I doubt a regular ole parts store is gonna have one. If you want a factory one go to ford and order one or go get one from a junk yard. Or you can get an aftermarket one.
Old March 17th, 2009, 11:21 PM   #16
phxstang's Avatar
2004 mustang v6
well today i replaced the pan but now its leakin from a little black seal that is between then oil pan and the tran oil pan
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Old March 17th, 2009, 11:30 PM   #17
There is a grommet in the bell housing for access to the torque converter drain plug. If that's where it's leaking from, I think there is a leak inside the bell housing, possibly from the seal in the front of the transmission. That seal is in the front of the transmission oil pump.
Threads Similar to: need tranny help
98 GT Tranny? '97'Cobra 4V / SVT 9 July 9th, 2008 02:41 AM
Tranny shifts hard - tuner frys tranny/engine? tangbang V6 Mustangs 4 May 27th, 2008 01:09 PM
Tranny Gone? Thejules 5.0 Mustangs 9 December 5th, 2007 02:47 PM
tranny jbm5781 96-98 6 August 8th, 2007 06:34 PM
tranny help 86stang 5.0 Mustangs 1 January 28th, 2007 03:44 PM
