#21 |
2003 V6 Mustang
Too long@Too slow
dude, once buddy explained it more clearly i understood it. in the original way he posted it, he used a dangling modifier, but once he went back and fixed the order of his words i understood it. notice how when i explained how i interpreted it to triple a, he understood my interpretation, and if the same sentence can be easily interpreted both ways, it is the fault of the writer not the reader (im not saying anything bad about you buddy, you were helpful in this) and if you would read and understood the other comments you would have understood that your posts were unneeded, so you have no room to insult anyone's reading comprehension skills
#22 | |
[8MINUS2]
#23 |
2003 V6 Mustang
Too long@Too slow
yes he did...quit trying to piss people off like you have a huge history of doing. how about growing up quit trying to put people down over the internet? nobody is influenced at all by your "demoralizing" comments.
#24 |
[8MINUS2]
I'm just wondering about this -hanging modifier- , didn't seem like anything was hard to follow. Then again I'm not an English major by any means. And secondly, do you think I care? Nope.
#25 |
2003 V6 Mustang
Too long@Too slow
i never said it was hard to follow, i showed and proved (triple a understood how i interpreted what buddy said) that there was more than 1 way to interpret what buddy said. if you didnt care, you should have responded maturely like triple a or buddy did. this is just you being you, and if you want to continue this, do it via pm.
#26 |
AC these motors are different
a 4.2 as just find geometry angles as a stroker unlike most v8s your thinking of ive already adress the issue with another distributor for parts Redlined Performance Mustangs and Super Six Motorsports is the only 2 distributors i would take into consideration RPM deals with Ross for their pistons Super six deals with Weisco for theirs both are well known names I have a spec sheet on 4.2 .030 pistons if your interested from what ive heard JEpistons with specs you can get pretty cheap vs these companies you would have to use SCAT 6.125 pistons that you can find on summit. they're for a 351w motor the crank is straight out of a 4.2L f150 v6 you can buy from ford for like $200
#27 |
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Thanks for the info...
#28 |
short answer is
3.8L n/a is 242rwhp by kirk 4.2L n/a is 274rwhp by justin2k however no one has tried a fully built n/a motor with this SSM intake. I would be curious to see what gains it gets. because are stock upper intake is horrible.
436rwhp/378rwtq tuned by HPP www.hppmotorsports.com - www.stangcharger.com - www.rpm-mustangs.com |
#29 |
MM's Mad Scientist
Slow Fella
I am just trying to get some round about figures. We have a guy in the area that is making 245 on the stock shortblock with a 3.8. So, I was just wondering if that was abnormal or pretty consistent with other results. I hope to be able to help him make 300 on his V6, but we will see where that goes.
#30 | |
as well as he will need higher compression. IMO
#31 |
2002 Ford Focus
slow as fuck
![]() iTrader: 4 reviews
its sad to see that the 3.8 doesnt have much of an aftermarket for intakes and absolutely no aftermarket for heads besides workin the stockers
99 V6 Mustang-sold 02 Ford Focus-sold 98 Camaro Z/28-lid, catback |
#32 | |
AC your good with heads im sure you could work something wild up as far as the cam and heads also a windstar upper or a SSX intake upper would be a better choice with a windstar upper and a built bottom through a C4 tranny super six made 260rwhp and 260rwtq im sure with a manual and a lighter rotating assembly and a meaner cam those figures can be worked on if your staying 3.8 the eagle I beams would be the lightest as far as the rods then a crank scrapper and deleting the Balance shaft are tiny little things to add more power
Threads Similar to: Biggest power NA V6?
| biggest turbo | 04mustang232 | The Clubhouse | 63 | September 29th, 2008 02:55 AM |
| Biggest A-hole | White99stang | The Clubhouse | 200 | September 28th, 2008 08:54 PM |
| Biggest Cam's | 330CubeGt | 96-98 | 19 | July 3rd, 2008 10:37 PM |
| what is the biggest tire | bigwhiskey | 5.0 Mustangs | 8 | September 10th, 2007 08:37 PM |
| The Biggest Retard | jealousy | Videos | 8 | October 13th, 2006 09:22 PM |
