Discussing Caster Camber plates in the V6 Mustangs Forum. I'm looking in to getting the caster camber plates from AM. How hard are ...
Old March 25th, 2009, 08:49 AM   #1
Mattman's Avatar
2001 V6
I'm looking in to getting the caster camber plates from AM. How hard are these to install? If any body has some info on this i'd appreciate it. Thanks
Originally Posted by commandersafi View Post
...I caught your fail....but who cares, its huggin time
Old March 25th, 2009, 01:09 PM   #2
2001 Mustang v6
254rwhp
They arent to bad, its just like takeing out your shocks. You have to take off the wheel. then with another jack you releave the tension off the spring. Undo the bolt that holds the shock in the factory mount. THe strut should fall out tjen just drill out the pop rivets and install the cc plate. took about an hour to do both for me, i also replaced the shocks wile i was at it.
MILITARY CREW
USArmy/SGT
Old March 25th, 2009, 03:54 PM   #3
'00 3.8L
+1 it's not hard, if you get the MM one's you'll have to drill a 4th hole in the strut tower but it's not too bad, remember to de-bur any holes you drill in metal to have a flush area for washers/nuts/bolts to sit on.
You'll have to take it to a suspension specialist / speed shop to have them adjust the plates to correct the caster/camber unless you want to try to find the numbers yourself and do it... I had a shop do mine when I got an alignment after... not expensive.
Old March 25th, 2009, 09:05 PM   #4
Mattman's Avatar
2001 V6
Cool. Thanks guys
Old March 26th, 2009, 04:47 PM   #5
phxstang's Avatar
2004 mustang v6
hey bro i did mine on my own i can help u out
-Cold air intake
-Dual magnaflow exhaust
-2" dropzone kit
-Caster and camber plates
-Weight reduction
-12000k HID
-Smoked tail and headlights
Old March 26th, 2009, 09:32 PM   #6
Mattman's Avatar
2001 V6
Really? awesome dude. I appreciate that. I'll let ya know when i order them
Old March 26th, 2009, 11:11 PM   #7
hyperstang00's Avatar
2000 V6 Mustang
i got the MM caster/camber plates. There is a template that is included with the kit to drill the fourth hole, so should be good..
2000 V6 Atlantic Blue GT Clone
True Duals
Flowmaster 40's originals
custom "H" pipe
Headers
Eibach Drop
Custom tuned w/SCT X3
and a lot more.....
Saving for my
NEW EDGE GT
Old March 26th, 2009, 11:37 PM   #8
Mattman's Avatar
2001 V6
thank you sir
Old March 27th, 2009, 01:40 AM   #9
phxstang's Avatar
2004 mustang v6
u can just go buy them at amp performance forlike 100 bucks
-Cold air intake
-2" dropzone kit
-Weight reduction
-12000k HID
Threads Similar to: Caster Camber plates
Which caster/camber plates Burn'nRubber 5.0 Mustangs 6 May 2nd, 2008 09:33 AM
Caster and Camber plates! gt_andy 99-04 13 March 1st, 2008 11:20 AM
caster camber plates ricks01 General Tech 5 August 6th, 2007 04:50 PM
camber caster plates Steves LX Suspension 2 February 20th, 2007 08:05 PM
Camber Caster Plates MustangMatt96GT 96-98 6 February 18th, 2007 10:04 AM
