2004 V6 Coupe
Very Odd Electrical Problem
Hello everyone, I just recently got a really odd electrical problem in my 2004 Mustang V6. I was playing around with my wires in the trunk that come off of my aftermarket amplifier, that power my aftermarket subwoofers, and I exerienced a slight problem. I forgot to unplug the battery and my power was still on. As I was touching the wires my stock radio (headunit) completely went out. It was as if it was turned off, but the power was still on. Then I realized my windsheild wipers did not work either, as if there was not power to those as well. Does anyone know what could be the problem? Is there any way to reset the electrical in the car, so I can see if that works?
Safud: MM's Resident Hadji
Check your fuses....I'm willing to bet you burnt some
Smelly Fists, Socking Cocks
Millenium Falcon
2004 V6 Coupe
yea, I thought it may be fuses, i was looking at the ones for the radio and windsheild wipers and they had what looked like burn marks at the top of the metal prongs. Also, I was just messing with the radio, and it looks like it is off with no power, but when I hold down the eject button it will eject a CD, could it still be a fuse if it has power to do that??
another dahm ford
ur eject botton is a feature that does not need same power as toturn radio on. it is based off your memory as most makers do. and ur fuses 1. are hard to look at and tell. spend the 4 minites and pull each one out from under ur dash. as well as under hood. i know 100% that ur radio is off two fused one under dash. and also one under hood. complete system is not ran from one. check all if thats no help pm me. i have complete wire layout. ill help ya out
#7 | |
That would help my project along nicely
another dahm ford
at the moment i have mine. 97 gt and v6. i can get yours beginning of next week. expect 50 pages lol. it is every color. loaction. end to end of wired, pin conector color, location and shape of connectors.and what all wires do. what are you trying to do maybe i can help right now before the work lol
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
#9 | |
I'm working on making a completely keyless starter. Here is the thread i made just showing a little of what i've done so far Phase 1 complete (somewhat) |
another dahm ford
from what i see all you need is push button now and you are finished. unless im missing something(take place of jumper) lol
#11 | |
the problem with the way it is in the video (not with the relay setup as im still working on it...with the one that im just using the jumper) is that it blows a fuse every time. I'm hoping by using the relays i'll avoid that and i should know by the end of tomorrow
another dahm ford
if i can find it (buddy found it a year ago in college and installed it on a camaro i sold him) but its a push buttom that has a outter ring such as the glowing ring on your colum. that is basically a older style key lock but with a puch botton in the center. so unless you know to turn it then puch botton you get nothing. ill see if i can find one. and ill look at my paperwork here at the house because you wiring is same as mine. ill see if i can scan it and get it to ya tonight
#13 | |
I'm in no rush to get it, so whenevers good for you
another dahm ford
wait so what are you trying to do then. u want a keyless start but still wana use a key. little conused lol
i had a similar problem but with the cigarette lighters, my radar decector would show power but wouldnt work at all.
i ended up tracing down the wire and hotwireing it to the fuse box lol |
I want the keyless starter, but i want to still be able to use the key if need be. I dont want to completely do away with the regular key abilities, because say one of my relays or switches goes bad...I'd be fucked and no way to start the car
another dahm ford
well not to be a downer but think about this. if you have a wire with a switch in it such as your video. or relays like you were saying u are trying. u cannot usa a key and have all that hooked up. it will not work. now you can run a keyless system with a puch botton. and if it ever goes out you can unplug everything and hook it back up under ur colum and use the key. but i see no way to use a keyless but still ablility to use a key. only way possible is to go buy a 100 dollar keyles start.. but it will be start by remote
#18 | |
And in that video, both the key and the switch works to turn on the car. |
Threads Similar to: Very Odd Electrical Problem
| electrical problem | 1BADSTANG | 5.0 Mustangs | 3 | October 13th, 2008 02:32 AM |
| very odd intermitent problem please help asap (excuse spelling) | 89lxstang5.0 | 5.0 Mustangs | 3 | March 25th, 2008 12:59 AM |
| Help...Electrical Problem | ZOOTOXIN | 99-04 | 20 | January 11th, 2008 05:12 PM |
| Electrical problem..... | Klawin | Audio/Video | 0 | September 18th, 2007 10:24 PM |
| Electrical Problem | 90Stang | 5.0 Mustangs | 12 | November 2nd, 2006 03:00 AM |
