02 Mustang V6
13.605 @ 101.60
![]() iTrader: 6 reviews
Dipstick Hits Something In Crankcase
So I thought it would be a good idea to remove the dipstick tube to install headers today. Well it worked and they got installed. Just put everything back together and now when I fired the car up it went clankety clankety clankety clankety, you get the idea... it's hitting something in the rotating assembly... SO
1) Anyone have a picture of a stock, unbent oil dipstick tube I can bend mine back to? 2) Anyone know a trick to cut down the section that goes into the crank case to clear such obstructions? 3) Somebody give me some hope
1996 ford mustang
is it leaking any oil from the bottom of the dip stick tube?
I found that it was difficult to get the dipstick tube in with the engine in the car. I had to remove the brake master cylinder to install it. Did you change the bends in the tube to clear the headers? Do you have the bolt back into it at the head? If the bends in the tube were changed I would suggest bending the bottom part away from the crankshaft centerline.
1996 ford mustang
the only way that your motor is gonna make noise from putting the dip stick in is if some how you broke the end off and it fell in ............. hopfully thats not the case or thats gonna be real shitty ............
#5 | |
02 Mustang V6
13.605 @ 101.60
Threads Similar to: Dipstick Hits Something In Crankcase
| anyone using a crankcase vacuum pump | rakkassan34 | 2005 - 2010 | 1 | August 4th, 2008 09:30 AM |
| crankcase vent filters??? | 02Gt Stang | 99-04 | 3 | August 4th, 2008 01:13 AM |
| Seafoam in Crankcase | I_eat_rice | 99-04 | 65 | March 30th, 2008 10:28 PM |
| If Gas Hits $3.50..... | mixedbreed02gt | The Clubhouse | 140 | February 26th, 2008 08:33 PM |
| Crankcase Evacuation Systems | smbikes | 5.0 Mustangs | 6 | October 20th, 2006 02:35 AM |
