Stupid 02 sensors
Hey guys I need your help again. I have finally got my car running and on the road again, after having to replace the fuel pump and filter and other parts because some dipbleep poured some crap in my tank and fouled that. Fixed the exhaust leak, Replaced the Mass Air Flow sensor, and had to replace the new car version of the distributer cap (can't think of what that is at the moment).
But now the freaking rear 02 sensors are bad. Well I am brokeand cannot replace those any time soon. Well I figured no worries, I have my X-cal3. So I hooked it up, and put in my new program to run on the premium fuel (BTW wow what a difference. She flat hauls now it is nice) and told it to turn them stupid things off. Well it says it turned them off, and the CEL went out for about 30 miles. Now it is back on telling me those two are bad. No other codes, just the two for them. Anyone have any ideas??? |
MM's Database Error
thats bc u cant turn on off the front ones i dont believe. u can turn off the codes but it will come back on bc there is actually something wrong that needs to be replaced
¡ʇsnq ɹo uʍop ǝpısdn
he said the rear ones are bad... and that he turned them off in the program.
double check that everything got saved and programmed correctly, thats my only though for now.
MM's Database Error
shit i missed that. then yea if he did it right they shouldnt be on. what code is it throwing? are you sure its the back ones throwing a code?
Well I think I am sure. This is what they are:
P0155 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) |
MM's Database Error
not positive but i think those are the front sensors not the rears
Yeah I would assume sensor 1 is in the front, as it wold be the first one to read the oxygen
2000 V6 vert Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears. |
MM's Database Error
i think it is, cuz if he turned the back ones off in the tuner then he wouldnt be catching codes like that. ill do some google work and check back
MM's Database Error
wow that was an easy quickie >>>
P0155 "This code refers to the front oxygen sensor on Bank 2. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0155. See also: P0135 (Bank 1)."
Well that makes since. I did not even think to double check the tech that did the work on what he wrote down for me. I will have to give him crap. Well that sucks, while those are on she still ain't going to run right. Guess I gotta do new ones.
Thanks all |
Threads Similar to: Stupid 02 sensors
| stupid, stupid, stupid question re: wheels | ReverendDexter | 4V / SVT | 6 | December 18th, 2008 01:41 AM |
| 02 sensors | gera8712 | 99-04 | 7 | September 10th, 2008 08:16 PM |
| o2 sensors | blazor | V6 Mustangs | 22 | April 17th, 2008 12:07 AM |
| o2 sensors | slow06stang | General Tech | 2 | May 19th, 2007 01:25 AM |
| Sensors | nHuman | 96-98 | 0 | February 24th, 2007 01:47 PM |
